Old 07-17-2017, 02:34 PM   #1
cardwellmarty's Avatar
Black water system
I'm a newbie as y'all can tell, I dumped the black water tank, I have see through fittings on my stinky slinky so I seen water come through, the indication light said 2/3 full, I dumped the tank and the indication light still says 2/3.
cardwellmarty is offline   Reply With Quote
Old 07-17-2017, 02:47 PM   #2
Learn to live without those indicators they will nonstop be incorrect with debris constantly getting stuck on the sensors. You can try to use a wand and flush the tank.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 07-17-2017, 04:13 PM   #3
007matman's Avatar
Do you have a black tank flush? Mine was right by the city water connection. I'd try that if you do. You'll want to open the black tank valve and then connect your water run it for 20-30 min or so at full open. That should help.
Mine does the same thing if I don't regularly flush.
007matman is online now   Reply With Quote
Old 07-17-2017, 08:45 PM   #4
I don't have one 007matman, so I reckon I need to take a water hose in the TT and flush it out.
Old 07-17-2017, 08:50 PM   #5
007matman's Avatar
You could install one or just get a wand. I'm sure your black tank is under the toilet like mine is so the wand would probably be the easiest.
Camco 40074 Flexible Swivel Stik with Shutoff Valve https://www.amazon.com/dp/B0006IX7YC..._lOwBzbP8JGWEF
Old 07-17-2017, 09:28 PM   #6
RandK-M's Avatar
Installed the Horst Miracle Probes on my last camper and liked them enough that I installed them on my new camper last year before even taking it out on the first trip. They aren't perfect, but much more accurate. Occasionally my black tank will read 1/3 right after dumping, but usually clears within 30 minutes. Most of the time however, it reads empty right after dumping even if I don't do the flush right away.
https://www.amazon.com/VALTERRA-T213...miracle+probes
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
RandK-M is offline   Reply With Quote
Old 07-17-2017, 09:44 PM   #7
Start using the Geo Method. Should help keep probes clean.
https://sites.google.com/site/cbruni/
2011 Traverse LT, 3.6L, FWD
Old 07-17-2017, 10:34 PM   #8
SailorSam20500's Avatar
Additional, though pricey options for sensors that mount outside the tank are:
SensaTank: SensaTank RV100 Multi Tank Monitoring System with Field-Effect sensing
Garnet SeeLevel: https://www.garnetinstruments.com/rv-shop/
I have not used either... Saw postings about them, made note for future mods if I get too annoyed with the ones that came with the RV.
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
black, black water, water
