Old 05-10-2021, 07:40 AM   #1
Black water tank flush
We purchased a 2019 31 SE Freedom express and it doesn’t have a black tank flush on it. Has anyone ever installed one on this model before? It has an enclosed underbelly.
Btmiller is offline   Reply With Quote
Old 05-10-2021, 08:53 AM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. I did not think any newer rigs came without a black tank flush with that said rig have survived for years without one. Some options you might consider is the Camco swivel stick I used this on my class A worked great without having to cut into the side of the rig and tank to install a clean out kit. JMHO about $21 for the stick or 39 to 150 for tank flush kit.
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-10-2021, 01:09 PM   #3
Always Learning
Not on that model, but I had a service center (not a dealer) install one on my Sabre years ago. Cheap part but they charged 60 or 90 minutes for labor so it got expensive. That had a covered underbelly and they had to remove a portion of it to get to the tank.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 05-10-2021, 08:21 PM   #4
Chris Pastuzyn's Avatar
I concur with Seadog,Get the stick,I made one,My black tank flushed didn't function properly from day 1,
Chris Pastuzyn is offline   Reply With Quote
Old 05-11-2021, 12:56 PM   #5
paladave's Avatar
Not sure if this is sufficient for you - but worked for me. I used the stick I think they referenced but my gauges were always suspect. Bought this doohickey and tried it for the first time, and it worked well.
Camco Rhino Blaster Sewer Tank
Rinser
https://www.amazon.com/dp/B00T36KRS2...roduct_details
Dave & Betty
Pittsburgh Area
Go Steelers
paladave is offline   Reply With Quote
Old 05-11-2021, 03:03 PM   #6
Rinser
I once had an older coach with a defective flush and used this same device. It works well.
2015 Forest River Solera 24R
2009 Honda CRV Toad
lacamastraveler is offline   Reply With Quote
Old 05-11-2021, 03:36 PM   #7
Rinser
That's good for rinsing out the discharge tube. But the water will never reach the tank itself.
You need one with a built-in valve.
https://www.amazon.com/Valterra-Degr...k+rins&sr=8-11
Iwritecode is offline   Reply With Quote
Old 05-11-2021, 04:04 PM   #8
Mr. Dan's Avatar
IWC, what is that extra, threaded piece? I’ve had a Flush King for many years… bought from the original FlushKing company but I’ve never seen that extra connection.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 42; Booked = 36
Old 05-12-2021, 07:19 AM   #9
The stick is also called a tank wand. Because it is hand held, you can move it around and make sure you really get things clean. Google GEO method if you haven't already. Calgon water softner eliminates a lot of problems.
mnoland30 is offline   Reply With Quote
Old 05-12-2021, 08:16 AM   #10
I honestly don't know. I just did a quick search and that's what came up.
My best guess is that it's a plug for the port where you connect the hose. So if you want to dump without the hose connected, it won't squirt out the top.
It's listed as an anti-siphon valve.
EDIT, I may have been wrong. Here it's shown in use:
black, black water, flush, tank, water, water tank
