Old 10-25-2011, 09:47 PM   #1
onequicksportster's Avatar
Blowing out water lines
where is the best place to hook up a air hose to blow out water lines to winterize.
2015 F250 psd CC Sb 4x4
2007 Wildcat 28rks 5'ver
2005 Harley Davidson
2009 Weimaraner "Dog"
onequicksportster is offline   Reply With Quote
Old 10-25-2011, 09:49 PM   #2
TURBS's Avatar
your city water fill inlet !
Old 10-25-2011, 09:50 PM   #3
TURBS's Avatar
with this duma jiggy
Old 10-25-2011, 10:51 PM   #4
Thanks a million!!
Old 10-26-2011, 06:05 AM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
I made up an adapter with a gate valve that screws into the City Water connection and has a quick connect for the air hose. That way I can move throughout the RV and open and close faucets, toilets etc to allow the water to escape. I can also do other things while the low point drain is allowing water out. I used a flexible connector so it hangs at a 45 degree angle.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-28-2011, 10:05 AM   #6
tonyz's Avatar
That makes sense to blow it out at the city water intake, but how can you blow out the line from the holding tank to the pump? Will it back pressure through the water pump and clear the line to the holding tank?
Tony Z
tonyz is offline   Reply With Quote
Old 10-28-2011, 10:24 AM   #7
acadianbob's Avatar
You can't blow out your holding tank. There should be a drain hose with a screw on plug at the bottom of your RV to drain it. Also, don't put any antifreeze (RV type) in your holding tank. Be careful how much air pressure you use when you blow out your lines. Check around but I believe you don't want to exceed 45 psi or so. But don't go in there with 100 psi or you could blow things to smitherines! Lots of people use pressure limiters on city water to avoid this problem.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-28-2011, 10:27 AM   #8
acadianbob's Avatar
I guess I didn't answer your question which was the line from the holding tank to the pump. You may have a valve near the pump that has a short hose for introducing RV antifreeze. After your holding tank is empty, open this valve and you may get enough "relief" in the line to allow any water in that line to flow back into the holding tank. I also use RV antifreeze to make absolutely sure that every drop of water is out of the pump. It doesn't take much water to ruin that pump; a few drops may be enough . . .
Old 10-28-2011, 10:35 AM   #9
Rugged Brown's Avatar
Attachment 8801
I thought that was a thingamajig.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 10-28-2011, 11:01 AM   #10
TURBS's Avatar
Its closely related to the muffler belt that I've seen some replace when in fact the blinker fluid was just low. Common mistake among rookies.
Old 10-28-2011, 11:17 AM   #11
And I'll be the first to admit that I often use a sky hook, when a simple come along will suffice.
Terry/Bernadette
Lily the Yorkie
2019 FR Vibe 28RL
Old 10-28-2011, 11:19 AM   #12
Anacortesians
I thought it was a "whatsit" or maybe a "doohickey". My grandfather use to say a "thingapurpose".
Frank and Eileen
No longer RVers or FR owners
Old 10-28-2011, 11:35 AM   #13
TURBS's Avatar
I guess I to have used a hoosker do when I should have used a Hoosker dont.
Old 10-28-2011, 11:51 AM   #14
I use this from CW.
Worldwide Merchandise Company - Blow Out Hose - Winterizing - Camping World
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
browne02 is offline   Reply With Quote
Old 10-28-2011, 11:57 AM   #15
(Kim)
Labzy's Avatar
LMAO, what the 'beep' are you guys even talking about?
It sounded good though......I almost googled sky hook......
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 10-28-2011, 12:38 PM   #16
mTn_biKer65's Avatar
I bought a spare compressor hose, cut off one end and inserted a hose adapter to screw directly onto the trailer. Worked almost 2 good as I found myself waiting a couple times for the compressor to get back to operating pressure. It goes out pretty quick when you're running around the trailer opening taps and flushing the toilet.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 10-28-2011, 12:56 PM   #17
stevengb's Avatar
I suggest filling the lines with rv antifreeze also after you blow the lines out at least that what my local rv dealer told me and it's what I did. May be overkill but that's better than finding out you didn't get all the water out of a valley.
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
Old 10-28-2011, 04:13 PM   #18
MtnGuy's Avatar
I blow all of my lines (with a bicycle pump), run antifreeze through all of the lines, then blow the antifreeze out. Some people say that I am anal.
Old 10-28-2011, 06:05 PM   #19
acadianbob's Avatar
Geez, Chap, I thought you were going to say you towed the 263 down to the Florida Keys!!! HA!
Old 10-29-2011, 09:39 AM   #20
MtnGuy's Avatar
Maybe the Crystal River area next March.
