Old 10-19-2012, 09:47 AM   #1
jt1920's Avatar
Blowing Out Water Lines
Our winters are generally mild here in the Pacific Northwest so we camp throughout the year and I don't do a full winterization of our rig. I drain the water heater, empty and remove the water filter, open all taps and pour RV antifreeze into each sink, the shower and my tanks after every trip. This year I'd like to take it a step further and blow my lines out but I want to be careful and not use too much air pressure. For those of you that use air to clear your lines what PSI do you set your air compressor to?
Thanks in advance for your help.
John, Laurie & the 2 Schnauzers
2008 Ford F350 6.4L CC SRW - 60th Anniversary Edition
2013 Cardinal 3030RL
B&W Companion Hitch
“Trail Air” air bag pin box
jt1920 is offline   Reply With Quote
Old 10-19-2012, 09:58 AM   #2
I set my compressor at 40 PSI. I really wouldn't go much higher then that.
Len & Cheri is offline   Reply With Quote
Old 10-19-2012, 10:17 AM   #3
TURBS's Avatar
25 psi is what's recommended.
Old 10-19-2012, 10:23 AM   #4
Who recommends 25?
Old 10-19-2012, 10:34 AM   #5
TURBS's Avatar
My flagstaff owners manual.
Old 10-19-2012, 10:40 AM   #6
Lynkage's Avatar
Pumps run between 40-45 psi and regulators are around 50-60psi, PEX is rated around 100psi.
40psi should be adequate pressure for doing this job for any trailer.
I do about 45-50psi as my system should handle that. If it fails there, it will when you least expect it!
Edit: I also carry a PEX crimper, pipe and fittings just in case!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 10-19-2012, 11:09 AM   #7
Crusader's Avatar
40 psi at a wholesale water meter...................so 40-45 is perfect.....thats what I have done mine at for 25 years of R.Ving, and have never had a problem yet.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 10-19-2012, 11:14 AM   #8
glenwood63's Avatar
Do you also use RV anti freeze in the water lines?
glenwood63 is offline   Reply With Quote
Old 10-19-2012, 11:30 AM   #9
Crusader's Avatar
No, The only anti freeze I use, is a cup of anti freeze down all drain traps. I also remove the H/W tank plug for the winter. The last thing I do is make sure that the holding tanks are empty from the drain traps old water.
Old 10-19-2012, 11:43 AM   #10
Fire Instructor's Avatar
I run my regulator down to about 30-35 psi. Keeps thge faucets from "spitting" too much. Higher air pressure,and you can damage lines (especially when you start exceeding 50 psi), plus it makes a splatter mess.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 10-19-2012, 11:48 AM   #11
Lynkage's Avatar
Originally Posted by Fire Instructor View Post
......... plus it makes a splatter mess.
I hang a hand towel over my faucets to keep that in check.
Shane & Antoinette
Old 10-19-2012, 11:51 AM   #12
TURBS's Avatar
I'm not saying 40 psi is right or wrong just stating what's in my manual.
Do as you please.
Turbs
Old 10-19-2012, 12:04 PM   #13
AquaMan's Avatar
If you have your faucets open, and your bottom drains it won't matter how much air pressure you use. You'll never be able to put enough air into the lines to build up any type of pressure to blow a line apart, unless you're using a commercial air compressor, and then you would have to have special fittings to accept the cfm it would take to bust a line. I have compressors from 40hp to battery operated, and I run 90-120psi from the compressor into the water line, and the back pressure guage barely moves.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 10-19-2012, 12:05 PM   #14
If you have a Flagstaff you need to use no more then 25 PSI, all others can use 40-45 Just picking at you Turbo. I was going to assign you an acronym by using your new "Free Advice Giver" name, but once I shortened just using the first letters it just wasn't right
Seriously to the OP, it's perfectly safe to 40PSI. Here are some links if you don't believe us:
Winterizing with Air
Country RV - RV Quick Tips
Americamp RV Sales
Old 10-19-2012, 12:10 PM   #15
TURBS's Avatar
Lol f.a.g
Good one!
Nope I upgraded to a wonderfull sabre!
It's all good!
Turbs
Old 10-19-2012, 12:47 PM   #16
Lynkage's Avatar
Originally Posted by f1100turbo View Post
Lol f.a.g
Good one!
It's all good!
Turbs
Now that was funny!!
Shane & Antoinette
