10-15-2021, 07:15 PM
Cousins
Bought a Zero G hose
I was not needing a new hose but I had read a lot of post about the Zero G hose. While in a returns store today, I found a 50’ Zero G hose. I asked it I could hook it up and test the hose. There was no water in the hose whatsoever abs it looked like someone took it out of the box and just folded it back up into the box. I pressure tested it and no leaks. I bought it for $16. It sure is easier to put up than the white camco hose I have.
2015 Forest River Cherokee Grey Wolf Limited
2011 F150 Supercrew Ecoboost Lariat 4WD
10-15-2021, 07:37 PM
Part-Time Campground Host
Been using zero gs for years. Great hose, durable, and easy to store.
Craig & Cath
Days camped since 2015(retirement): 1687
10-15-2021, 08:12 PM
Though we routinely use a Zero G hose to connect to the black tank flushing port, we don’t use one for the city water connection or fresh water tank fill, as we were under the impression it was not fit for drinking water use. Any thoughts or insight is welcome.
Mr. Brian
2020 Forest River Forester 3011 DSF
10-15-2021, 08:25 PM
Retired Old Fart
They are made by Apex, and all the advertising says they are drinking water safe. I would not use the same hose for black tank flush and drinking water though!!!
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
10-15-2021, 08:32 PM
Cousins
It says on the side of the box that it is safe for drinking water.
10-15-2021, 09:03 PM
I have 2, both boxes say safe for drinking, mine are Apex. My neighbors is Zero-G, same things, all 3 came from CW
Use and enjoy
10-15-2021, 09:11 PM
I have had a couple of these types of hoses. Not these brands. On the two that I had, the fittings were of very poor quality and the hose only last a short time before it started leaking through the fabric.
How is the quality of these tow hoses?
10-15-2021, 10:04 PM
Cousins
The zero G hose does not expand and retract like some of the hoses that folks are familiar with. It is similar to a small diameter fire hose. It will fold up without kinking or roll up without kinking.
10-15-2021, 10:05 PM
Originally Posted by dward51
…I would not use the same hose for black tank flush and drinking water though!!!
Ditto. Thanks. We’ll have to take another look when it comes time to replace our (separate) drinking water hose.
Mr. Brian
10-15-2021, 10:26 PM
Always Learning
I've used mine for years. I want to say a good 3-4 years now. Using quick connects vs. constantly twisting it seems to extend the life vs. friends who go through one every 12-18 months or so.
I've all but given up on traditional hoses at this point, I love it so much.
10-16-2021, 12:13 AM
I think they make 2 different hoses. A blue hose which is good for drinking and a black hose that is not. If it is good for drinking water it will say so on the box.
I have three 25’ hoses. I love them as they fold up so easy. I have all three in a Tupperware type plastic tote that is probably 14” long by 6” wide by 14” tall with a latch lid. The white Camco hoses were always a pain to coil and we stiff when cold. Plus they kinked easy. Zero-G for me!
10-16-2021, 02:53 AM
They are nice hoses and recommend them. I have a 25 foot Marine Zero G that's blue and use that for the city water. I'll put the excess amount of hose mainly under trailer to keep it out of direct sunlight during the warm days. Also have a black 25 foot for the black water flush. They do wrap up and store great. I also have a black 100 footer (going on 6 years of age) that I use at the house and don't have any complaints with it.
John Fertsch - HAM=KJ6MTJ - GMRS=WRQZ336
2021 Forest River Wildwood X-Lite 24RLXL
5300 Dry, Max 7500, Easy Lift Recurve R3 WDH
2019 Ram 1500 Bighorn - 5.7 Hemi with 3.21 Gears
Max tow is 8500 LBS with 1788 Payload capability.
10-16-2021, 04:35 AM
Defender of America
Have a 50' black hose to flush out black tank. Keep it separate from drinking water supplies (so I don't get confused). Connections are better than any other hose I've owned. Never thought about quick disconnect fittings to alleviate the twisting but think it's a good idea and I'll give it a whirl.
The 25' ones are so hard to find I'm starting to think they don't exist.
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
10-16-2021, 06:48 AM
We’ve been using them for a few years now and they have held up great.
Have a 50’ for black tank flush and 2 25’ for drinking water hookup.
Found shorter food safe buckets at Menards that fit through the opening in the storage compartment we keep them in. Take up a lot less room than the tote we used to have.
Store nicely and much easier to work with.
2014 3051S - First RV for us
10-16-2021, 09:23 AM
As I mentioned, I love mine, the only draw back is the male end has a plastic sleeve that goes over the male end to help with twisting, that part is not so great as you can't really get ahold of the male coupler... thus the quick disconnects, they make it magical
Enjoy
10-16-2021, 10:23 AM
Our Zero G failed on its third use, Teknor provided a full refund, no plans to try another.
10-16-2021, 12:22 PM
We typically use the old faithful white Camco hose for most campsites, but I have a green 75 ft Zero G Pro for sites that have hookups that are away from the pad. I also have to use it when I have the trailer at home, because there isn't a faucet near my driveway. No issues with it.
I haven’t been everywhere, but it’s on my list.
2021 Geo Pro G16BH
2012 Nissan Armada 4x4 Platinum
10-16-2021, 12:29 PM
Several mentions about quick connects. Any opinions on the Banjo cam & groove connectors? Having good luck with them but only using about six months. Much easier to connect than the brass push pull connectors.
BIRDS AREN’T REAL
10-16-2021, 04:54 PM
Just got my 2nd Zero G, first lasted 6 years, a little faded but worked great and easy to pick up and store, love it.
10-16-2021, 05:15 PM
We also purchased and used the Zero G Hose until I watch a Video on another forum showing a gentleman cutting one open and showing the condition of the interior of the Hose. Never again. Needless to say I replaced the Hose with a Camco and the Zero G is now in the yard...
2021 Rockwood Ultra Lite 2883ws
2020 Ram CTD Crew Cab SRW Laramie
