01-07-2020, 10:35 PM
#21
Looks like inflight refueling
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
01-08-2020, 01:52 PM
#22
Originally Posted by Scheinin
I purchase the Viper Sewer Hose Kit because this forum said it was one of the best systems, including the fact that it is crush proof. What I didn't expect was a cicada, in shedding it's shell, gripped on the center portion of the hose and punctured it.
I cannot find a realistic way to patch this hole, while maintaining the ability to compress the hose for storage. Any suggestions?
Unless I missed it, how big of a hole are you dealing with. I caught what did it, just never read what size the hole was.
Wondering if a piece of tire patch for a bicycle tire might not solve your issue when glued over hole.Should remain flexible.
Curious minds want to know what worked.
Get out and have a good day on purpose cause everyday on this side of the grass is such a great time.
Nothing lasts forever, So live it up,laugh it off, take chances, & never have regrets, because at one point, everything you did was exactly what you wanted.
01-08-2020, 07:04 PM
#23
Global Nomad
The hole was just smaller than a nickel. After various attempts, the solution appears to be a hot glue. I filled the hole with glue, starting at the circumference and working my way in. I let it harden completely. Because of the temperature, I folded the hose up and put it away. Today I took the hose out and emptied my tanks. No Leakes. Again, because of temperature, collapsed hose and put away. When the temperature warms up, I might reinforce glue with spray flex (that black stuff). That did not work by itself. So far, so good.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
01-13-2020, 07:41 PM
#24
Bug did it
You had a lot of suggestions, if nothing else works you could try Aquaseal. I have the Viper and love it
01-13-2020, 08:07 PM
#25
Try a vinyl repair kit
01-13-2020, 08:44 PM
#26
Hose Storage
Shortly after purchasing our RV we investigated the back bumper. Yup. Metal.
Not wanting a rust issue we purchased an 8' long section of PVC porch post. It is about 6" square. Glued a post cap on one end. On the other end we drilled a couple of holes through the end of the post right through the post cap. Then inserted "L" shaped bolts in the holes. The cap doesn't have a chance of coming off. The whole thing was attached to the underside of the camper with strapping.
Six years in and still works like a charm. Camper in storage but I can try to get some pictures later.
Heather & Jim
2017 Ford F150 4x4 EcoBoost
2013 Rockwood 2703WS
01-13-2020, 10:43 PM
#27
There is no rear bumper tube on a 5th wheel.
Say what?!? Why would you say that? Shall I post a picture of my Outdoors RV with a rear bumper and sewer hose storage? It's factory installed. Along with a receiver hitch.
01-14-2020, 12:21 AM
#28
Global Nomad
Keep up, I corrected that.
Steven J. Scheinin
01-14-2020, 10:53 AM
#29
Originally Posted by Herk7769
So, why the question about bumpers was asked is that rust can and will form inside the tube (more or less based on the climate and salt content of the air). That rust and road vibration can wear holes in a sewer hose stored inside.
There is also this potential issue …
Easy Fix !!!
Install - Pin- Nail or small Bolt in end cap !!!
Also first install plastic rain gutter in bumper before Hose !!!
01-14-2020, 11:17 AM
#30
Originally Posted by Reverse_snowbird
Collapsing and gluing the ridges together sounds like the best suggestion.
A cicada? That's one tough bug. Probably thought your hose was a tree.....
I use clear silicon calk an it lasts forever on any small hole in my sewer hose and does not affect the collapsing of it much at all.
01-14-2020, 11:55 AM
#31
Global Nomad
Thank you. Since I borrowed the hot glue gun, I will try silicon calk should this happen again. So far, the hot glue has held up fine.
Steven J. Scheinin
01-14-2020, 12:01 PM
#32
Hot Glue gets very hard compared to Silicon calk and it will not flex like silicon. Make sure you clean area with alcohol first.
01-20-2020, 07:57 AM
#33
Easy fix
Vinyl repair found at auto store or another product called waiter repair. I’ve used on tests on both ATV and snowmobile seats, which are very flexible
01-21-2020, 12:47 AM
#34
Global Nomad
So far, the glue is working great.
Steven J. Scheinin
01-21-2020, 10:12 AM
#35
Ham Call N8SAC
What do you do when the hose won’t fit in the bumper. I put mine in the back of truck. After loosing one many TT ago have never carried one in bumper. When I get home I wash and sanitize it and store on a crate in trailer.
01-21-2020, 04:15 PM
#36
Global Nomad
My Cedar Creek has a large basement. I bought a large rubbermaid storage container that I holds all my hoses, drain connections, hose slinky, etc. It is water tight, has a lid, and fits nicely in my basement.
Steven J. Scheinin
