Old 11-25-2020, 12:29 PM   #1
Camco electric water heater core install problem
Trying to install the Camco electric water heater core into my Atwood 6 gal gas water heater. Just getting the current plug out is a chore because the gas line and other pieces are right in front of the plug. The Camco unit sticks out even further and the gas line and and other pieces are in the way. Am I out of luck trying to make this work? Anybody run into this? see attached pic
donkro is offline   Reply With Quote
Old 11-25-2020, 12:30 PM   #2
sorry pic uploaded upside down
Old 11-25-2020, 12:33 PM   #3
Chris Pastuzyn's Avatar
Depending on how comfortable you are with taking out that gas valve ? Than you can get crafty and replumb that drain valve .
Chris Pastuzyn is offline   Reply With Quote
Old 11-25-2020, 12:33 PM   #4
third time a charm?
Old 11-25-2020, 12:34 PM   #5
sorry it's not letting me upload upright! what the heck!
Old 11-25-2020, 01:10 PM   #6
Head Rambler
When taking a picture with your phone hold it with the 'bottom' on the right in landscape mode. That will usually allow the pic to post right on forums.
Can you take a little wider and post it? That might allow us to give you some suggestions of how to replumb it.
Gotta go campin!
Old 11-25-2020, 01:26 PM   #7
Witch Doctor's Avatar
that’s a drain plug not the electrical rod.
Old 11-25-2020, 01:34 PM   #8
what is the model # of your Atwood W/H.
Old 11-25-2020, 01:45 PM   #9
What exactly are you calling a "Camco water heater core"?
If it is what is in the first photo below, you shouldn't be.
An Atwood tank is aluminum and does not need an anode rod.
There should have been a plastic/nylon drain plug only in your tank.
If you simply want a petcock for draining, install a 45º adapter of the correct size and just screw a petcock into the adapter.
You could also replace the petcock with a T-handle to one with a knob...
Final question.... are you trying to install an electric element into a gas only water heater?
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 11-25-2020, 01:54 PM   #10
third time a charm?
How about this?...
Old 11-25-2020, 02:02 PM   #11
Ejs4029's Avatar
My guess is the OP is trying to install a Camco RV Hot Water Hybrid Heat
ID:	243643   Click image for larger version
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 11-25-2020, 02:11 PM   #12
Yes that's what I'm trying to install, gas line stuff is right in the way. There's a guy on youtube with same unit as mine and his went in super easy. And now I'm thinking it will be a pain to winterize. Has anybody just installed a point of use heater inside the coach? I have a class C.
Old 11-25-2020, 02:13 PM   #13
Since we frequently stay at campgrounds with electricity, it seems having an electric source of heated water would be easier and less expensive than gas, especially since we're already paying for the electric.
Old 11-25-2020, 02:25 PM   #14
You certainly could install an on-demand water heater but that would take some work and most are propane so no real advantage over what you have. All electric ones are pretty expensive.
The conversion rod does make draining the tank a bit of a chore.
You could always consider replacing your current water heater with the model that has the element. (located in the rear on an Atwood) Of course this would require an electrical circuit be run to the water heater from the power distribution box for it to be factory like. You 'could' put a plug on the end of the supply line and simply plug it into an extension cord to the pedestal.
Or... you could just use propane.
I realize the on-board LP tank of a motorhome limits your capacity somewhat but you could always supplement your LP with a portable external tank plumbed in one of several ways.
Old 11-25-2020, 02:26 PM   #15
dmctlc's Avatar
Why not just replace the HW heater with a Truma tankless electric HW heater and you'll have all the hot water you want. Granted up front cost aren't cheap but worth it with usually enough hot water to keep everyone happy in the family. Though I'm not sure if they're dual fuel meaning do they have ones that have gas and electric. I have the electric version in my Class A and we are very happy with it so far. Thanks
Dana & Terri - (Retired)
Stephanie (daughter)/Rick/Callie (12 y/o)
Phillip (son)/Alyssa/Charlotte (4 y/o)
Our Cocker Spaniel "Shadow" (4 y/o)
dmctlc is offline   Reply With Quote
Old 11-25-2020, 02:40 PM   #16
bikendan's Avatar
Maybe the OP dry camps or boondocks and likes to have the propane option. A Truma would be useless in that case.
We do and would never have a electric only WH or fridge.
Old 11-25-2020, 02:57 PM   #17
Thinking something like this? Opinions?
https://www.tanklesswaterheaterdepot...t-water-heater
Old 11-25-2020, 03:10 PM   #18
dmctlc's Avatar
I agree but looking at a point of use (POU) can be expensive and leave him in the same situation when and if he's boondocking. I guess the OP will need to decide but a POU is just that, only good for one place not covering everything in the rig. Plus, IMHO, POU hot water heaters take up space.
Old 11-25-2020, 03:16 PM   #19
we do boondock so would like to keep the gas fired hot water heater hooked up, just would like the electric option when in a campground. I'm thinking I could hook it up before or after the gas heater. This Rheem unit runs on 110v and uses 29amps and says can be used in an Rv, also looks pretty small. My unit provides 30amps, so couldn't use anything else when this would be on.
Old 11-25-2020, 03:40 PM   #20
this Bosch unit looks interesting, only uses 12amps, but would require a bit more space as it has a tank
https://www.amazon.com/dp/B0148O65IE...783400601&th=1
electric, heater, water, water heater
