Old 12-08-2020, 01:26 PM   #1
Can anyone tell me what this piece is called
I seem to have sprung a leak and it looks like itís the plastic piece that has the water lines attached . It appears easy to replace but Iíll need to order it and I can imagine what to call it. Click image for larger version
Joshicmc is offline   Reply With Quote
Old 12-08-2020, 01:37 PM   #2
Mr. Dan's Avatar
Originally Posted by Joshicmc View Post
I seem to have sprung a leak and it looks like it’s the plastic piece that has the water lines attached . It appears easy to replace but I’ll need to order it and I can imagine what to call it. Attachment 244249
To which piece are you referring?
Now I see your edit. It looks like a 3-way water valve.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 12-08-2020, 01:41 PM   #3
Mr. Dan's Avatar
Maybe the valve is OK and the leak is coming from one of the hose connections.
Old 12-08-2020, 01:42 PM   #4
fonzie's Avatar
https://www.amazon.com/Flair-16912-P...452907&sr=8-11
Fonzie
Old 12-08-2020, 01:43 PM   #5
Ejs4029's Avatar
3 way by pass valve...Assuming it's just not one of your hoses leaking at the PEX connection. If you think it maybe leaking on one of the hose connections and not the PEX try using a small band clamp.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 12-08-2020, 01:46 PM   #6
Always Learning
Agreed.
For the OP, to find out, wrap a little bit of toilet paper around each end of the valve. It should give you an idea of where the leak is a bit more accurately.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 12-08-2020, 01:56 PM   #7
Flybob's Avatar
On a side note, those bypass valves tend to stick as they are usually only used twice a year. When ever turning them, try to hold the valve with one hand and turn it with the other so you do not stress the connections.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-08-2020, 02:21 PM   #8
I seem to have sprung a leak and it looks like itís the plastic piece that has the water lines attached . It appears easy to replace but Iíll need to order it and I can imagine what to call it. Attachment 244249
Diverter valves for diverting to bypass or to hot water tank. Should be available at any RV store.
bzac1954 is offline   Reply With Quote
Old 12-08-2020, 02:59 PM   #9
DAISY BOYKIN's Avatar
Ss clamps
Harbor Freight has a package of small SS hose clamps of assorted small sizes.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2019 41 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 12-08-2020, 03:50 PM   #10
And 'maybe' it isn't even leaking at the bypass valve but rather where the PLASTIC fitting screws onto the water heater inlet. It could be running back the line and dripping off the valve. The fitting on the water heater has a cone shaped washer in it and is only to be finger tight. Sometimes they don't even get them finger tight at the factory.
Doug's suggestion of the technique of using pieces of toilet paper or small pieces of tissue is good advice to narrow down troublesome leaks.
I'm surprised your dealer didn't explain about the bypass valves when you had your PDI/Customer Orientation? (if you bought new)
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 12-09-2020, 12:48 PM   #11
KyDan's Avatar
Be careful of Harbor Freight hose clamps. I bought an assortment box and found they are sub standard. Even a medium tight and the threads strip out and the clamp pops loose. I wound up getting some honest SS clamps at AutoZone.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 12-09-2020, 01:37 PM   #12
Or better yet.. this type. Fuel injection hose clamp.
https://media.napaonline.com/is/image/GenuinePartsCompany/NWMDC?$Product=GenuinePartsCompany/3660225
StrangeBird22 is offline   Reply With Quote
Old 12-09-2020, 02:29 PM   #13
SailorSam20500's Avatar
Generally, I would pass on band clamps on pex tubing. The flat spot on the band clamp often results in leaks. Pex really needs a clamp that puts even pressure all the way around.
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 12-19-2020, 09:54 PM   #14
That sent me to a water pump when I clicked it. Weirdest hose clamp ever.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
led
