Old 05-08-2022, 10:49 AM   #1
Can I add an anti-siphon to my overflows?
Finally got around to pulling the corroplast down from under my fresh tank. Turns out, that was easy. They used a nice wooden strip across the main frame members and used normal screws to attach the corroplast. Nice.
I have always had issues with my overflows on my fresh tank when I filled up. They would siphon a lot of water out of the fresh tank. Now that I can see the install, I can see how a lot of slosh going down the road combined with siphoning would do that.
My question: Would there be any benefit to trying to install anti-siphons where the overflow exits the tank at the side? I may be able to get that elbow off, but maybe not. It was installed before the fresh tank was installed and there isn't enough room to turn the elbow because it hits the flooring above. I might be able to find a way to remove it if the recommendation is that an anti-siphon would help.
There are two overflow outlets, one on each side.
Whadya think?
The overflow is the one on the right. The one on the left is the fill.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL
Andersen Ultimate
1200W solar > 412 Ah LiFePO4 > Victron MultiPlus II > Cerbo GX
corn18 is offline   Reply With Quote
Old 05-08-2022, 11:26 AM   #2
bubbles's Avatar
Holding tank "overflow" is typically the tank vent tube and you say you have 2. I see a vent (overflow), a fill and either a drain or water pump tube. If a drain could the other side tube be the water pump feed? Just thoughts. Siphoning has been an ongoing pia for a long time.
Old 05-08-2022, 12:23 PM   #3
The second over flow is on the other end of the tank.
Andersen Ultimate
Old 05-08-2022, 04:52 PM   #4
bubbles's Avatar
Well, if you have 2 overflows just cap off the one that is giving you issues. Only one vent is needed, and the other overflow can act as that.
Old 05-08-2022, 11:41 PM   #5
A anti siphon/check valve can not be used on a tank vent. When filling the tank the air in the tank must be able to exit. When drawing water out of the tank air must be able to flow in or the tank will collapse due to the negative pressure inside.
The vent hose should rise a few inches above the top of the tank before turning and going down below the tank, this will prevent siphoning. This may not be possible in your situation.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 05-09-2022, 04:47 AM   #6
A check valve and anti-siphon valve are two different valves with different functions.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 05-09-2022, 07:35 AM   #7
The way the photo is posted, the top of the tank is at the bottom of the photo and the elbow at the lower right with the blue pex is your vent/overflow, correct?
markb422 is offline   Reply With Quote
Old 05-09-2022, 08:56 AM   #8
The nearly 50 years of owning/remodeling/maintaining this house hasn't given me a bit of experience with what I've chased in my trailer. My trailer is gravity feed, so we're on different pages there also.
I don't see a siphon issue (unless there is a tube inside the fitting going lower in the tank). Water can't drain below the level of the fitting. That said, I can see that driving and sloshing can slop water out the drains.
My manual solution would be to put a valve on each of the overflows. Fill the tank. Close the valves. Drive all over and slosh the tank without losing a drop. Park, open the valve and you're in business.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
Old 05-09-2022, 10:07 AM   #9
Overflow
I would never put a valve on an overflow. You are asking for trouble. Now a siphon preventer is perfectly fine. I bench tested mine with the tank out. Works fine, allows me to keep the tank full after driving all day, but allows for any pressure out. (I had to remove the tank because Cardinal didn’t properly support the tank, so I made a support and cured the low tank capacity problem.)
stepdad is offline   Reply With Quote
Old 05-09-2022, 10:20 AM   #10
just add a longer overflow line and loop it above the tank .
MR.M is offline   Reply With Quote
Old 05-09-2022, 11:17 AM   #11
Trailer Trash
Captain Insaino's Avatar
To this point, are the vent hoses higher than the fill hose and hardware end to end?
2017 Palomino-Real-Lite Mini-RL-177
Typical Boondocking mods
Captain Insaino is offline   Reply With Quote
Old 05-09-2022, 11:34 AM   #12
NMWildcat's Avatar
Most folks I know (including myself) have valves on their fresh tank overflow due to siphoning/slosh whatever you want to call it.
On a gravity fill system it is not a problem if you forget to open the valve. Gravity fill caps are not air tight, so when using water from the tank, it will not pull a suction. When filling with the valve closed, it will remind you to open it when it pukes water back at you when about half full if you are filling too fast.
On the pressure/pump fill systems you do have to be aware of what you are doing to ensure the valve is open when using/filling tank, so a siphon preventer might be safer.
Always have to be smarter than what you are playing with.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 05-09-2022, 11:44 AM   #13
In the picture, the two hoses coming out of the top is the top of the fresh water tank. The one on the left is city water fill. The one on the right is the overflow. There is the same thing on the other end of the tank.
The hose from the overflow elbow just goes straight down through the corroplast and ends just below the corroplast. I made a mod where I added a hose to the end of the overflow hose and brought that back up along the outside of the frame and attached it at floor height. Did that on both sides. I think that may have alleviated any siphoning. I did notice we didn't lose nearly as much water with the added hose going back up to the top of the tank level. Maybe I am chasing ghosts.
Andersen Ultimate
Old 05-09-2022, 12:21 PM   #14
Trailer Trash
I'm no hydrodynamics professor, but wouldn't a vent above it all solve your problems?
Old 05-09-2022, 03:08 PM   #15
All that's necessary to prevent siphoning out water is a tiny vent. I'd try rotating the overflow fitting so it points a bit above horizontal then install an extension to the drain tube that you attach to the floor above the tank then to the original drain tube. Once you know where the attach point is, drill a small (1/16 or 3/32) hole in the top of the tube under the clamp at the attach point. This tiny vent will break the vacuum that forms when a slosh of water fills the overflow tube with liquid. Putting the hole under the clamp will help prevent dust from entering the tube.
I did this with the overflow on my 2011 Georgetown and completely eliminated siphoning while traveling.
Phil
pmsherman is offline   Reply With Quote
Old 05-09-2022, 03:21 PM   #16
Phil
That sounds like a great idea. Will give that a go.
Andersen Ultimate
Old 05-10-2022, 07:39 AM   #17
dwilli1's Avatar
That would've been my recommendation.
2021 Cherokee 274RK towed by:
2020 GMC 2500HD AT4 w/Duramax 6.6 Diesel
Fastway e2 Equalizer Hitch
dwilli1 is offline   Reply With Quote
Old 05-10-2022, 10:12 AM   #18
A Valve on the overflow is kind of like a crank-up TV antenna. Will work great until you forget to open it when filling. Just like lowering the antenna before moving.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
