I'm still learning our first TT, a 2016 Evo T2050 which according to specs has a 56-gallon fresh water tank. It's a gravity fill with a small screened tank vent next to the gravity fill cap.
No matter how slowly I fill it, I can't get even close to 56 gallons in there. I'm using one of those
Camco water tank fillers attached to the end of the hose, which has a valve to let me adjust the flow to a trickle, and I've placed an
Orbit Water Flow Meter in line to monitor how much I've put in the tank.
Today, I started with a drained tank to be sure. At around 28-30 gallons the vent started burping. At around 36-38 gallons the vent stopped burping. At 42 gallons, water began to flow from the gravity fill, even when the hose was barely dripping. That flow continued even after pulling the hose, and it seemed like as much was coming out as was going in so I stopped even though theoretically I should be able to get another 14 gallons in there. But another 14 gallons isn't trivial.
Is this normal?
