Old 08-25-2020, 07:45 AM   #1
Cardinal sink leak 4 water lines?
I have a 2020 Cardinal with a leak under the bathroom sink. There are 4 water lines. Hot and cold to the faucet and two others that go into a black plastic free moving box. Itís leaking at that black box. I donít know what that black box is for. A pressure regulator? Is it necessary?
JPSCOTT123 is offline   Reply With Quote
Old 08-25-2020, 07:57 AM   #2
Mr Towed's Avatar
Is it the back side of an outdoor shower?
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
Mr Towed is offline   Reply With Quote
Old 08-25-2020, 08:06 AM   #3
GFAR's Avatar
That is the valve for the black tank flush I think, does it look like this?Click image for larger version
GFAR is offline   Reply With Quote
Old 08-25-2020, 08:07 AM   #4
I donít think so. It looks like a cold water line going into this plastic box and a cold line going out. The box is leaking.
Old 08-25-2020, 08:10 AM   #5
Why would that leak if there’s no hose attached to the outside flush system?
Old 08-25-2020, 08:12 AM   #6
B and B's Avatar
Could be water backing up from the line due to atmospheric pressure.
Old 08-25-2020, 08:21 AM   #7
GFAR's Avatar
Do you have a picture? Iím just guessing what it is!
Old 08-25-2020, 08:27 AM   #8
I had a hose connected to the flush system with the water off. I disconnected it and the pressure was released as well as water. No more leak! Thanks! But what does that valve do? I assume the water goes into it from the outside hose and out into the tank sprayers. But what does the valve do? Is it a back flow valve?
Old 08-25-2020, 08:57 AM   #9
Commercial Member
ES_FR's Avatar
JPSCOTT123,
We would be happy to assist you with this leak in your 2020 Cardinal. Because your ongoing satisfaction is very important to us, we invite you to contact Rod Batts in our Customer service department through the following personalized and direct link: http://www.forestriverinc.com/Direct...36061484750818.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 08-25-2020, 01:52 PM   #10
GFAR's Avatar
It is to stop back flow of water from getting into your clean water line or tank from the black tank flush
Old 08-25-2020, 07:39 PM   #11
Danesville's Avatar
A vacuum breaker
Danesville is offline   Reply With Quote
Old 08-25-2020, 07:51 PM   #12
If itís leaking either replace it or remove it completely. Mine failed on my camper and made a royal mess when it flooded the camper. I removed mine completely.
phipps33 is offline   Reply With Quote
cardinal, leak, sink, water
