Old 12-27-2020, 07:13 AM   #1
Chassis support of water tank bent under weight of tank
Apparently this is a known issue...
Unbelievable they did not change the design or just used larger iron.
Will have to postpone my next trip as this is a dangerous situation.
Not good FR...
Filos Hippos is offline   Reply With Quote
Old 12-28-2020, 10:08 AM   #2
larry2c's Avatar
As you noted, this is a common complaint. I have replaced the thinner angle iron brackets with heavier "C" channel on our TT and it reduced the bowing significantly.
Regarding cancelling your upcoming trip - can you travel there with the FW tank empty and then get water at the campground? There isn't much risk of the tank dropping our if the trailer is just sitting at a campsite. Bouncing around on the road - well that's another matter.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
bent, tank, water, water tank, weight
