07-25-2020, 03:22 PM
City water connection
Hello
I am just curious if others have this happen.
We have a 2011 Sunseeker 3120DS.
When we disconnect from the city water connection, water shoots out like there is still pressure in the system.
This just started to occur. We usually just have a little drop or dribble of water when we unscrew the fresh water hose.
Thank you,
Randy
07-25-2020, 03:52 PM
PhD, Common Sense
Originally Posted by rhughsless
Hello
Thank you,
Randy
This would, by no means, be your final solution, but does running water from the kitchen sink after turning the spigot off release the pressure somewhat before you disconnect the hose?
BTW, do you disconnect from the spigot or from the camper first?
07-25-2020, 04:00 PM
If there is a screen washer in the city water connection remove it and look inside the connection to see a pressure valve that may not be fully sealing off. A toothpick or small screw driver can be used to reposition the valve. it should be evident once you see the valve. Should look something like this
07-25-2020, 04:09 PM
As bubbles mentioned, it is likely your back flow valve. Occasionally crud/insects can get in the water hose and then get stuck in the valve preventing from closing. You can use a flash light to look in and check this.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-25-2020, 04:37 PM
Hello
Thank you,
Randy
By chance, is your water pump turned on?
Brian & Becky
2018 Avenger ATI 27RBS
07-25-2020, 06:37 PM
The purpose of the check valve is to not allow water to come out the connection when the water pump is used. All cold water plumbing (excluding black tank flush plumbing which is self contained and isolated from all other plumbing) is connected together and the check valve at the city water location is to prevent an open port for water to exit when the water pump is used in lieu of city water. It serves the same function as the water pump internal check valve which is supposed to prevent city water pressure from entering the holding tank while using shore (city) water input. If the check valve is not seating correctly and no faucets are open when city water is disconnected residual cold water plumbing water will flow back out till pressure is equalized.
07-25-2020, 07:04 PM
There IS pressure in the system the second you connect to city water. Unless you relieve that pressure by opening a faucet -- or disconnecting the hose * -- the pressure remains. * As noted there should be a check valve to keep trailer water from going into the hose.
Try this home experiment with your garden hose with a nozzle on the end. Turn the water on, let it run, the close the nozzle. Turn the faucet off. Want to guess what happens when you disconnect the hose? Yep, same thing here.
-- Chuck
07-25-2020, 07:14 PM
No.
We have always camped using full book ups.
I have never used the water pump.
Thank you for the question
07-25-2020, 07:15 PM
Hello
Thank you,
Randy
Every camper we have ever owned does this unless we leave a faucet on inside to relieve pressure. There can also be some pressure in the hose..
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-25-2020, 07:17 PM
Hello
We disconnect from the spigot first. I thought about turning on the kitchen faucet to relieve pressure,but that was after we had already disconnected.
We never have had this happen until this year.
Thank you.
07-25-2020, 07:19 PM
Hello Bubbles.
I was wondering if the valve was the culprit in this.
Thank you for the reply.
I will try this tomorrow.
Thanks again
07-25-2020, 07:32 PM
Hello Flybob.
I will look at the back flow valve tomorrow.
Thank you for your service to our country.
Thank you for the response.
07-25-2020, 09:01 PM
Hello Oaklevel.
Normally when we disconnect the water it does leak a little. The last couple of times though it has been more forceful.
I will still check the valve tomorrow as suggested by other members.
Thank you for your reply.
