04-21-2021, 12:49 PM
City water foaming at the sink
We just began having water at the sink foam a little on cold water. It was about time to replace water filter thinking that could be it. After doing so we still are getting a foaming issue. Any ideas?
Thanks JFK
04-21-2021, 12:55 PM
Is this the first time you've had the camper out from winter storage?
Could be a bit of RV antifreeze trapped in the plumbing.
Brian & Becky
2018 Avenger ATI 27RBS
04-21-2021, 01:03 PM
Yep... R/V antifreeze will make the water foamy.
Is this something that just started or is this the 1st time out?
Are you using water from a hose connected to city water?
What does the water look like coming out of the hose?
Had you winterized using antifreeze?
Did you by chance put antifreeze in the fresh tank to winterize?
If you put antifreeze in your fresh tank, it takes LOTS and LOTs of flushing to get it out. it is NOT recommended you winterize by adding antifreeze to the fresh tank. There are far better ways.
If you used antifreeze, did you flush and sanitize the system prior to use?
Do you remove the water filter cartridge before winterizing? You might have a water filter where the cartridge might still have antifreeze in it?
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
04-21-2021, 01:12 PM
If the OP has never winterized or put "anti-freeze" in the system
Foamy like soapy or foamy like heavily aerated?
If the bubbles last a bit like dish soap I would suspect a chemical problem like anti freeze.
If there is just a lot of short lived foamy water I would be looking at the faucet design. Many faucets let a significant amount of water drain out of the spout when turned off. When turned on the air in the spout super aerates the first bit of water.
Looks interesting but is not a problem.
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
04-21-2021, 01:30 PM
No we have been in it since October, it has never been winterized. Never had this problem before.
04-21-2021, 01:38 PM
What is your water source?
04-21-2021, 01:41 PM
Start at the main faucet with a clear water glass. See if that foams. Then connect each hose, filter etc in line and check with the water glass.
In my case it was the white water hose that was causing the foaming. Changed hose (threw the old one out) and foaming stopped.
04-21-2021, 02:07 PM
City water connection
04-21-2021, 02:10 PM
It is a city water connection at your bricks & Sticks home or a RV Campground?
Maybe the Campsite or the city where you are located are treating their water?
Also check the aerators on your faucet. is it only the kitchen sink? Like mentioned maybe a new faucet with a different aerator.
Days Camping
04-21-2021, 02:13 PM
So foam only at one sink then?
04-21-2021, 02:16 PM
Did you just sanitize? I have seen some types of bleach (anti-splash) foam, I once used the anti-splash and it foamed for awhile, it eventually quit.
04-22-2021, 01:13 PM
Our bathroom sink started foaming last week(looked milky). Ran some water in a glass and watched it clear up within a minute. Turned out to be air, the piece on the end of the faucet needed to be cleaned out. Hopefully your issue is that simple.
04-22-2021, 01:21 PM
This happens occasionally in my house. Just notice it once in a while in different faucets from time to time.
04-22-2021, 03:20 PM
Thanks I think air may be the issue!
04-23-2021, 08:33 AM
If not chemicals, must be air infiltration. May be coming from the source that way. May be a small leak in your connecting hose, or at a fitting. If you have a drip at one of your fittings, it means you also could be sucking air when using the water. Might be the parks faucet also. I've seen many that drip no matter what you do, and for the same reason above, if it's dripping, it can also suck air.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
04-23-2021, 08:36 AM
I've had this problem over the years usually the first time I start up the water but even when I hookup to campground water. To me it's air in the lines, either the water hose, in the RV lines or even in the city water connection. I usually have to go to each faucet and even the toilets and bleed it off. Doesn't take much and once it's done at least at the particular site I don't have anymore issues. Originally I thought it was a hose issue and switch them out and it didn't matter. Also it's happened on more than one RV. In fact it just happened last week on the Motorhome.
Dana & Terri - (Retired)
Our Cocker Spaniel "Shadow" (6 y/o)
Stephanie (daughter)/Rick/Callie (14 y/o)
Great Granddaughter - Cora (2 y/o)
Great Grandson - Zek (1 y/o)
Phillip (son)/Charlotte (6 y/o)
04-23-2021, 10:32 AM
Thanks I agree!
