Old 10-25-2015, 12:33 PM   #1
City water thru filter?
I never carry water in my TT. The type of camping we are doing presently puts us in camps that always have a water connection so I don't see the sense in carrying around all that extra weight. For those rare times we might need to spend one night pulled over in a parking lot just to sleep, we plan ahead and carry 4-5 gallon jugs of water for morning coffee and other needs.
My question ... does a city water connection go thru the water filter? Or does it by-pass it with the assumption that a city connection is already filtered? Just wondering if I need to continue to change the filter every year or not.
Thanks.
gastan is offline   Reply With Quote
Old 10-25-2015, 12:47 PM   #2
Ford Idaho's Avatar
IF your unit has a built in water filter city water SHOULD go thru it.
I use a inline filter that gets replaced at the start of the camping season regardless of how much it was used the season before.
Old 10-25-2015, 01:06 PM   #3
bubbles's Avatar
If you have a built in water filter typically it is a whole house filter and all non heated water passes thru it, regardless of where it comes from (shore/holding tank).
Old 10-27-2015, 01:51 PM   #4
Blackhat6mike's Avatar
I have an onboard filter that all water EXCEPT to the toilet flows through it. Why filter toilet water other than to keep trash out? The pump and T to the toilet are prefilter.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 10-27-2015, 01:58 PM   #5
I filter all the water that enters the trailer, through an inline filter attached that the city water inlet. I do not have a separate inline for toilet water.
David 01 is offline   Reply With Quote
Old 10-27-2015, 05:09 PM   #6
Ford Idaho's Avatar
Nor do I, betting that separating the toilet from the rest of the unit was a plumbing nightmare......
Old 10-28-2015, 01:01 PM   #7
D_B Travelers's Avatar
Filter for City Water
We are similar in that we camp with full hookups most of the time and the trailer has a system filter for all incoming water. That said we added city water to the fresh holding tank in Wichita KS this past June and finished our trip about a week later without emptying it out or having to use it. The water in the fresh tank developed a very bad odor which the main filter would not remove. We ended up dumping the tank, adding a chemical just for this purpose ( I forget which one) to the new fresh water and letting it sit for a week or so. It did get rid of the odor and we are good, but now we use an additional filter at the shore connection all the time. I have not noticed any drop in water pressure with both filters connected and now if we want to carry fresh water in the tank we can fill up knowing it is filtered. The blue filters that fit on the supply hose end are not expensive and are easy to use; I just dump the water out of mine and store it on top of the hose in the bay.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 10-28-2015, 03:06 PM   #8
vfp
I'm not sure that is a good idea David. We just bought a filter because our toilet was stopped up. Apparently trash in the water had accumulated over time to the point where the toilet would barely flush.
vfp is offline   Reply With Quote
Old 10-28-2015, 04:17 PM   #9
We filter all water. On board filter when using city water and when filling at state parks, use a filter on the fill hose.
Have read that some campers run into sand or grit in water supply. Don't want to have that mess!
2016 Wildwood 26TBSS
2012 F150 Screw XLT
4 legger Halley
TreeLady is offline   Reply With Quote
Old 10-28-2015, 06:37 PM   #10
camping baba's Avatar
We have the whole house filter that came in our 5er . In the spring I will remove it and use a inline filter .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
Old 10-28-2015, 06:42 PM   #11
B and B's Avatar
The installed factory filter does both tank water and city water in my trailer.
B and B
Old 10-28-2015, 07:12 PM   #12
X2, but my toilet line Tees off pre-filter and post check valve of the city water. Always had super water pressure at the toilet except when it was new and stopped up with plastic trash. Cleared it out and has worked fine since.
Old 10-29-2015, 07:50 AM   #13
Thanks.
I would still use an in line filter I worked at a campground all the plumbing was out dated iron pipe every time you turned water on you would get a shot of rusty water.
Myrle is offline   Reply With Quote
Old 10-29-2015, 08:07 AM   #14
mcnabbwr's Avatar
We travel to many different areas and are never sure of water quality. We utilize a dual canister filter system to remove sediment and improve taste. We run all incoming water through it wether it's tank or city side.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-29-2015, 08:11 AM   #15
northstar1960's Avatar
You got well water . it will start to smell like rotten eggs in about a week of storage . when ever i know i'm getting well water i make sure it's only in unit for a few days . will really get bad in hwh if left in
northstar1960 is offline   Reply With Quote
Old 10-29-2015, 08:31 AM   #16
WFD
Be careful with storing filters in the bay, on top of the hose as you say...if you are not using the trailer for a few days, a week, whatever, it gets awfully warm in those storage bays and whatever is in that filter can grow and become a science project...when not in use those filters should actually be stored in a fridge.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-29-2015, 08:42 AM   #17
kdot's Avatar
On the advice of my dealer, when winterizing, I took the filter out, wrapped it in a sandwich bag, and put it in the freezer compartment in the house refrigerator. He said that would kill the bacteria in it and I could put it back in the canister next Spring. Does that seem like good advice?
kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
kdot is offline   Reply With Quote
Old 10-29-2015, 09:17 AM   #18
Thanks for all the great answers. I'll keep replacing the filter each year. And after reading some of these answers I think I'll look into an inline filter as well.
Old 10-29-2015, 09:45 AM   #19
mcnabbwr's Avatar
kdot
I would replace it every year at least. Due to usage I replace a minimum of twice a season.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
Old 10-29-2015, 03:54 PM   #20
thebrakeman's Avatar
Maybe these were rhetorical questions, but:
Either way, we probably all change the onboard filter every year. It's not like filtering the water going to the toilet will cause anyone to change the filter more often (unless perhaps you're full-time, and actually use a counter).
Plus, that's a 3rd water line that has to be run to the bathroom. Which means more antifreeze to winterize. For me, that would mean having to purchase a 2nd gallon, then store most of it til next year.
thebrakeman is offline   Reply With Quote
water
