Originally Posted by NavyLCDR
An overflow (vent) should not have a shutoff valve on it. Leave the valve closed and you take the chance of either pressurizing the tank during filling, or drawing a vacuum on the tank when using water from it.
True... but... there have been multiple posts here of folks losing their fresh water tank contents due to siphoning going down the road and most of them have put a shut-off valve on the overflow. Not saying this is what the OP has but it could be.
One other thing... at a recent R/V show we seen two units that were pre-plumbed for a washer/dryer and there was a plastic pan on the floor with a drain attached so if the washer overfilled/leaked, it would catch in the pan and run out the drain to the outside.
