Thank you for your response. I made the mistake of presenting the idea to the DW. She immediately said "You get it replaced, I don't want to be out and all of sudden the black empties." So now I am ordering all the replacement parts to rebuild that section completely.
The tank hub, street 90, and Bristol flange all came out together without too much struggle. Since its all glued together, its rebuild another set and re-install.
Any suggestions on the butyl sealant for the hub going into the black tank? I was able to loosen the hose clamp holding it in, and then gently twisted and pulled on the hub and the sealant was flexible enough to give way.
Thanks again.
CDSpark
2017 Georgetown 30X3
