Old 05-30-2020, 05:28 AM   #1
Dewinterizing
Obviously a newbie. Dewinterizing my 2507s with a water pure filter system. Cannot figure out to get water to water pump. Pump works fine but nothing coming out faucets. Did I miss a valve that should be open or closed? Thanks
Cmundy is offline   Reply With Quote
Old 05-30-2020, 07:32 AM   #2
how did you get the antifreeze into the rv when it was winterized? connect a city water hose where you pulled in the antifreeze, turn it on, and then go open all the faucets.
i don't know your rv but it either has a gravity fill port for putting water into the fresh water tank or it has a valve that directs water from the city water input port into the tank rather than sending it to the plumbing lines. if you have that valve hook the city water hose up to the city water input port and flip the valve to fill the fresh water tank.
depending on the model you may also have a valve that changes the water pump suction port from the fresh water tank to a separate antifreeze input port. if you pumped antifreeze in this valve was changed to the antifreeze port. change it back so the pump sucks from the fresh water tank.
after you flush out the anti freeze remember to reset the hot water bypass valves.
when you say the water pure filter system did you take the cartridge out before you pumped antifreeze? if the cartridge has been sitting in antifreeze you may want to change it with a new cartridge after you flush the antifreeze.
hope this helps!
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 05-30-2020, 07:53 AM   #3
Very helpful. Sounds like the antifreeze valve. I did pump the antifreeze in and remove the filter cartridge. Thank you!!!
Old 05-30-2020, 07:56 AM   #4
Hi All,
Good morning. Just another day in Paradise. I know it sounds silly but you do have to have water in your tank for the pump to work. Hooking up to city water directly will not fill your tank.
Have a great weekend.
F
U.S. Navy (Retired)
Lake of the Ozarks
2020 Rockwood 2104S
2017 F-150 3.5 2nd Gen
catcottf is offline   Reply With Quote
Old 05-30-2020, 08:18 AM   #5
the antifreeze valve directs the pump suction input to pump from either the tank or the antifreeze inlet port.
several options to get water into the plumbing lines to flush out the antifreeze:
1. hook up city water and use it to flush the lines. this may not get the antifreeze out of the pump itself as the pump is not used)
2. get water into the tank and then use the pump to flush the lines (antifreeze valve must be in the normal or tank position).
3. get a large bucket of water, put a hose into it connected to the antifreeze input port, and use the pump to draw water from the bucket and into the lines (antifreeze valve must be in winterize setting).
you'll get it!
Old 05-30-2020, 08:26 AM   #6
Fresh water tank is full. This plumbing is much different then our Jayco greyhawk rv.
Our first trip will be couple miles away. Thanks for all the tips!!
Old 05-30-2020, 09:13 AM   #7
Tapex's Avatar
you'll get it!
X2...as CHICKDOE posted!
2016 Coachmen Apex 250RLS Ultra Light
2019 Ram Big Horn Sport Longhorn
Tapex is online now   Reply With Quote
Old 05-30-2020, 10:22 AM   #8
Dewinterizing
Should the antifreeze valve be parallel or perpendicular to the blue water line to use the fresh water tank
Thanks again
Old 05-30-2020, 10:53 AM   #9
Tapex's Avatar
Thanks again
Can you post a picture of your valve?
Old 05-30-2020, 10:56 AM   #10
LittleBill's Avatar
Should the antifreeze valve be parallel or perpendicular to the blue water lineto use the fresh water tank?
Thanks again
Normally when a valve is parallel to it's line it is open, while perpendicular to it's line it is closed. Not necessarily to some other line in the system. Another way to check to see if your antifreeze valve is open/closed is after you have water in tank, turn on water pump then check the end of the antifreeze line to see if you hear it trying to suck liquid. If it is then the valve is open, if not then it is closed.
A picture of your valves and lines would help everybody here to better analyse your situation.
Read through this thread that WMTire (a site mgr) put together that may help with your question - https://www.forestriverforums.com/fo...st-103381.html.
Good luck and happy camping - Be Safe
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2015 Chevy 2500HD Crew Cab 4X4 SRW Duramax
Demco AutoSlide 18k
GMRCK25D - Rear Axle Timbren SES Suspension Upgrade
LittleBill is offline   Reply With Quote
Old 05-30-2020, 11:06 AM   #11
Kanadian Kamper
kenandterry's Avatar
Thanks again
Typically, you want the valve to mimic the flow direction of whatever fluid you’re using.....water, antifreeze, booze?
Ken and Terry
2018 Sunseeker 2430S
and might rarely get pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 06-16-2020, 05:43 AM   #12
Called factory they were very helpful. Told me the faucets in the shower probably did not get tephlon taped when sower miser installed. Took to dealer all fixed!
Old 06-16-2020, 10:03 PM   #13
LittleBill's Avatar
Glad it is all working for you now. Safe travels
Demco AutoSlide 18k
winter, winterizing
