Old 04-10-2017, 09:47 AM   #1
Do I need to sanitize/flush fresh tank & water lines?
Picked up my new sunseeker motorhome a week ago and my biggest question is whether I need to sanitize and flush the fresh water tank + lines if I plan to use the water for drinking?
I have a blue Camco water filter for my hose, have a built-in water filter in the RV, and I use a britta water filter once the water comes out of the tap. That's a lot of filters but is it sufficient or should I sanitize? Would love to hear from people who did and did not do this when they got their RV.
It's worth noting that I'm in California and it's doubtful any antifreeze was in the tank/lines but I'm double checking this with my dealer, as that probably makes a difference.
alexisc is offline   Reply With Quote
Old 04-10-2017, 09:50 AM   #2
Yep I would suggest to correctly sanitize before use. Not expensive, it is recommended by Manufacturer and why not.
gloryracing is offline   Reply With Quote
Old 04-10-2017, 10:00 AM   #3
Yes you should.
Even though it is a new tank and you have lots of filters, you really should start out with a sanitized tank and plumbing system.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 04-10-2017, 09:09 PM   #4
Thanks, everyone
Old 04-10-2017, 09:19 PM   #5
WFD
It's probably more important for you to sanitize than it is for many of us living in northern climates. My tanks are frozen for about 4 mths of the yr(at least), yours never are and can have "stuff" growing in there year round.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-11-2017, 07:47 PM   #6
I can't imagine it's any worse than my apartment water lines. I've lived in the same place for years and I don't believe the lines have ever been cleaned, and I drink the water. How much worse can a motorhome be?
Old 04-11-2017, 07:56 PM   #7
Flybob's Avatar
Sometime before you took delivery of the unit, the water tank was filled and the water system was tested. After that it was drained, however you can never get all the water out. That means that water has been sitting in the lines and in the water tank creating mold and other not so nice things. Sanitizing costs a small amount of bleach and less than an hour. Definitely sanitize filters can only do so much.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-11-2017, 08:03 PM   #8
Cardinal Gerry
Short reply...YES!
GerryReviea is offline   Reply With Quote
Old 04-11-2017, 08:12 PM   #9
This is probably the first thing I've read that's convincing me to do it
Old 04-11-2017, 08:17 PM   #10
Always.
Nascon is offline   Reply With Quote
Old 04-11-2017, 08:36 PM   #11
Yes! Sanitize!
Lacrosse40 is offline   Reply With Quote
Old 04-11-2017, 11:11 PM   #12
jtesta1's Avatar
If you ever seen some of the crap they leave in the tanks during manufacturing you wouldn't hesitate to clean it twice.
jtesta1 is offline   Reply With Quote
Old 04-11-2017, 11:26 PM   #13
SailorSam20500's Avatar
If your apartment water supply is from a municipal system, it is probably chlorinated water. While the chlorine or chloramine level is low, it does provide continuous sanitization.
With that said, those of us with grey or thinning hair probably drank a lot of water from common garden hoses and have survived!
My opinion, do you really need to sanitize? Probably not if you only use good clean water and even better if at least some of the water you put in is municipal sourced and pre-chlorinated. Will sanitizing the system hurt? Definitely not and if something nasty does get started you may avoid a case of Montezuma's revenge.
My bottom line - sanitizing is cheap to do and takes little time - it is cheap, easy insurance. So why not just do it?
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 04-12-2017, 10:05 AM   #14
I am from California also. We do not winterize but when we will not be using our rig for awhile we always fill the tank with 1/4 cup bleach per 15 gals. of tank capacity. Run it through your faucets, etc. Let it sit or even better pull it around for part of the day. Drain it the next day and fill with fresh water and run it through faucets,etc to get the bleach out. Drain system and refill. You should be good to go. It sounds harder than it is when you read about it. By the way, those Camco blue filters can start growing some stuff in them after using and storing. It probably wouldn't hurt to run some bleach through them also. I also replace my rigs water filter when done which you mentioned you have. Haven't gotten sick yet. Good luck and Happy Camping.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 8529IKBS Classic Platinum Edition
Beauty and Beast is offline   Reply With Quote
Old 04-12-2017, 10:20 AM   #15
Hoglou's Avatar
X2 on the 1/4 cup per 15. Every spring for us.
Hoglou the DH (01.01.21 done and retired)
BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 04-12-2017, 10:24 AM   #16
OLD DLR
Yes
Clorinate
Then filter
When hooked up
Many places do clean water any way
ALLEND55 is offline   Reply With Quote
Old 04-12-2017, 10:28 AM   #17
Prime Member
Do you need to sanitize and flush? No
Should you sanitize and flush? Definitely.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 04-12-2017, 11:04 AM   #18
1/4 bleach is s good idea. Personally, I never drink from the faucets. I only drink bottled water I travel with from my good Sierra springs well. It also depends on how long the water has been in the tank inbetween trips and the outside temps.
mtnlvr is offline   Reply With Quote
Old 04-12-2017, 12:43 PM   #19
Retired
MainelyUS's Avatar
Check this article out (March 2017 Trailer Life) by Chris Dougherty RV 101: Getting Ready to Roll
Happy Trails
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is offline   Reply With Quote
Old 04-12-2017, 12:58 PM   #20
DouglasReid's Avatar
Then why ask our opinions if you don't heed them? Most are offered out of our own experiences/problems.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
flush, tank, water
