Old 09-12-2017, 11:40 AM   #1
Dometic 310 leaks
2015 Nitro XLR the dometic toilet was leaking around the plastic base and ceramic bowl. I bought a new 310 and when I looked at the old one I found that the base and bowl could be separated and the gaskets could be replaced except Dometic does not sell those gaskets. I believe a little silicone or maybe plumbers grease could have resolved this problem.
nitro jim is offline   Reply With Quote
Old 09-13-2017, 03:23 PM   #2
Was the original Dometic toilet a model 300? If so, this model did have a problem with leakage and Dometic offered warranty replacements with an upgraded toilet. IF you had a model 300 and still have the unit, record the serial number and contact Dometic. They "may" offer a solution to the cost of the new 310.
l001952119 is offline   Reply With Quote
dometic, leak
