02-18-2020, 04:45 PM
#21
Originally Posted by 5picker
Is your toilet directly over the black tank with a straight shot into the tank or does the pipe have one (or possibly two) 45º ells?
I had a SOB (some other brand) with the two 45's and it was a real bugger to get the toilet to flush the pipe clean.
Solids and paper would catch at one of the ells, causing some backup and then it 'seemed' as though the tank was full when it wasn't. It would start burping and showing some water in the pipe after one day.
I finally cut the pipe and found there had been an EXCESSIVE amount of glue used to join the pipe and elbows and the pipe was nearly closed off.
After repairing, there never was another issue.
I had some concerns on our current model because it too has the 45's in the pipe.
I've not had a single issue with this R/V in over 3 years. When it burps, the black tank really is full.
The toilet is not directly over the tank. There’s at least 1 45 degree bend in it. I can’t see into the tank, that’s for sure. When I look at the pipe in my storage area, it has one visible 45 degree bend in it.
02-18-2020, 05:27 PM
#22
Unfortunately, from my research, most 5th wheels have the angles, not a straight shot to the tank. That's why I recommend the flexible wand, best $25 dollars I've ever spent. Don't know why but a garden hose just doesn't do it.
2018 Flagstaff Classic Lite
2018 Silverado 2500 Diesel
4 legged buddy Fletcher
02-18-2020, 06:04 PM
#23
OK, if quite a lot comes out when you open the dump valves, and you still have water in the pipe without adding any more water or s---, and you have a drop tube (or whatever exactly it is called) with bends in it, the problem almost has to be either in that pipe or the mound that has built up underneath has grown so high that it is blocking the end of the tube. Have you been able to run something flexible down the toilet so that it gets all the way into the black tank?
I'd try either plunging it (very gently) or running a something flexible down the tube to clear the pipe. Nothing other than a clog in the pipe or at the base of the pipe makes any sense.
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
02-18-2020, 07:10 PM
#24
Make sure
Years ago. we had visitors and one of the ladies used hemmoroid wipes and dropped it down the toilet. it clogged my toilet right now. Make sure no one uses any kind of wipes in those kind of toilets. I had to pull the toilet and take the wipes out of it and it worked like new again. Sounds like the same thing I had going on.
02-18-2020, 08:47 PM
#25
Is this what you’re referring to?
Camco RV Flexible Swivel Stik with Shutoff Valve- Creates Powerful Cleaning Action that Dislodges and Flushes Stubborn Waste Deposits and Combats Odors (40074) https://www.amazon.com/dp/B0006IX7YC..._bmjtEbAKJ03ZS
02-18-2020, 08:48 PM
#26
Plunging works temporarily. We put a garden hose down there, but I don’t think it hit anything.
I’m suspecting it’s a mound in the tank at this point, so that’s where my efforts are going.
02-18-2020, 08:49 PM
#27
Since we’ve only had this rig for two months, it’s possible the previous owner put stuff down there they shouldn’t have. I know for sure that we haven’t.
02-18-2020, 09:08 PM
#28
Interesting problem and discussion. Please let us know what you finally determine the cause to be.
02-18-2020, 09:21 PM
#29
One of those inexpensive endoscopes/borescopes for a cell phone might give you a better idea of the problem.
They can be had for $10. Throw it away when you are done with it for that price.
02-18-2020, 11:28 PM
#30
Will probably look at getting one of these as well.
02-19-2020, 12:26 AM
#31
Well, you could have found why they traded it in.
I still stand by my theory of the wipes in the toilet. I don't mean to sound gross but after a couple of BM's it starts to clog and acting like that. You will have to take it apart and pull the wipes out of it and be glad that they didn't get into the tank. ITS GOING TO GET MESSY!!
02-19-2020, 10:13 AM
#32
That''s one of them. If you don't have waste in the bowl it's not even that messy. 5 gallon bucket, something to carry everything in, disposable gloves and disinfecting wipes and your all set. Let me know how it turns out.
02-19-2020, 10:26 AM
#33
We had this exact problem last year on our Silverback toilet/black tank. The first time it happened I was able to probe the toilet drain with a stiff wire (had a power line marker flag in the back of my truck luckily) and get the water down the drain and working again. The second time it happened I purchased an inexpensive sewer snake and gave the tank a good cleaning from top and bottom. I chased it with a lot of water after, filling the tank with a hose a couple of times.
I think I have it pretty clean now, but we're being a bit more careful about what goes down there!
Dave in SK
VE5DLC
Trailer: 2011 Cedar Creek Silverback 35K
Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
02-19-2020, 10:54 AM
#34
Sounds like you bought some one elses problem
TT: 2018 Coachmen Catalina
243rbs(rear bath) legacy edition
TV: 2022 Ram 2500HD Tradesman
02-19-2020, 10:58 AM
#35
Drag a garden hose in there. Alot more pressure than a wand
02-19-2020, 01:25 PM
#36
The brand I bought was TankTech, it blasts the sludge with a small opening on the end and can snake around corners.
02-19-2020, 02:22 PM
#37
I tend to park in the same spot for a week or more. Fortunately my black tank is directly under the toilet pipe, so I can see buildup when it occurs. I use one of those orange snow sticks, which is long, thin, and rigid to "stir" the "mound of doom" until it breaks up. The stick is easy to rinse and store. Works every time!
02-19-2020, 03:41 PM
#38
Here’s an update:
I let the tank sit full with water and Happy Camper treatment for 2 days. I dumped the tank today. I bought a flexible cleaning wand and went to work. My wife said it took a while, but it finally ran clear, after a lot of waste and toilet paper came out. I filled and dumped the tank 3 more times until clear water finally ran out of it.
I filled the tank again with water and Happy Camper, and will see what it looks like tomorrow.
If that still doesn’t clear up the issue, I’ll go on the roof and check the vent to see if it’s clogged.
02-19-2020, 03:55 PM
#39
Another option to consider, which may be a bit of a pain, is to fill the black tank up about 25% and take the rig for ride down the road with twists and turns, etc. The sloshing in the tank will help to break if the sediment (mounds). We often times do this with our tanks when breaking down camp.....drop 5 gallons of water with Pine-sol in it and after driving many hours, we dump when we get home. Keeps the tanks clean(er).
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
02-19-2020, 04:51 PM
#40
Right now that isn’t an option. I have to get a new brake controller put in the truck before I can tow it.
