01-28-2023, 08:45 PM
#21
Originally Posted by l001952119
I installed a 320 today. Bowl held water for a "few" minutes. Now to gain warranty on new toilet!
Pour in hot water and let it sit. It will hold water
2015 Forest River Georgetown 270S
2012 Ford Fiesta
01-28-2023, 09:16 PM
#22
Originally Posted by Bob K4TAX
OK understand. Water expands as it freezes. In an enclosed environment that can and does break things. I don't see the toilet bowl as enclosed.
Anyway, I lubricate the seal about twice a year in our Dometic 310 with food-grade silicone grease. Some use Vasoline which also works.
It is just one of those items in an RV that requires regular maintenance. Also for the non-RV people visiting, be sure they are instructed on how to properly use the toilet. Saves cleaning up a mess later.
Bob
Originally Posted by Larry-NC
Okay, Bob. Why food grade? You're not planning to dine from the bowl, are you?
Does not contain any petroleum-based chemicals that can damage the rubber ring.
In the Service, the head had to be clean enough to eat out of. Otherwise, one scrubs the entire barracks floor with a toothbrush.
Bob
But doesn't Vaseline contain petroleum products and you suggested earlier, was OK to use?
Sent from my SM-G996U using Forest River Forums mobile app
01-28-2023, 09:24 PM
#23
Perhaps he's looking out for a dog that might decide to take a drink.
I believe the bowl valve seal is neoprene and could care less if it encounters petroleum based products.
Sent from my SM-N950U1 using Forest River Forums mobile app
01-29-2023, 09:50 AM
#24
Nope, it's rubber.
01-30-2023, 08:37 AM
#25
I use Plumber's Grease to lube the seal. Bought it in Lowes.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
02-01-2023, 01:05 PM
#26
Originally Posted by bubbles
Nope, it's rubber.
But which of the 10 different compositions of rubber is it?
02-01-2023, 02:14 PM
#27
I believe it is made from a blend of rubbers but is not synthetic (neoprene). Blends are most likely not published.
02-01-2023, 03:51 PM
#28
That's strange as most "seals" are made from Synthetics. Most common are Nitrile (NBR) and Neoprene due to both chemical resistance as well as abrasion resistance.
02-03-2023, 06:02 AM
#29
Originally Posted by Gnomads
I upgraded from a Dometic 310 to 320. Not too bad other than twisting myself into a pretzel lol.
My issue is that the seal is off centered. I took it out and reseated it a few times, tried the hot water and that worked for a bit. Now the winter and it will not hold the antifreeze. I know the manual says to not take the toilet apart but I feel if I can get to the seal holder I can center the seal ring. I included a picture.
Is there any reason why I shouldn't separate the base?
I installed a Dometic 320 in my camper last season and it would not seal good enough to hold water for more than a day. After trying everthing to greasing it, resealing it I emailed Dometic suggesting the new seal wasn't good and they sent me a new seal which has worked great. Maybe your toilet was sitting in a warehouse for too long and the seal hardened and needs to be replaced.
2020 Northern Spirit 1943RB
2017 Toyota Tundra SR5
02-03-2023, 06:34 AM
#30
Maybe. Will give it. Shot
2012 Ford Fiesta
02-08-2023, 02:18 PM
#31
Crisco vegetable shortening works well for lubricating most all of the rubber or similar type gaskets you will encounter. Use a spoon to extract enough for the job so that the cook in the camper doesn't get upset that the shortening has become contaminated.
2022 MiniLite 2109s
2018 F-150 XLT 4x4, 3.5L, Max tow pkg
2019 Ranger Lariat 4x4 (in reserve)
(We're just getting started!)
