Old 07-30-2023, 08:17 AM   #1
Mike223's Avatar
Dometic Toilet Leak
I noticed water coming out from under the left of my toilet opposite side from my foot pedal where the water valve is. Seems to only do it when you flush? Maybe flush valve needs replacing or toilet replacement? Don't know what model toilet. Dometic basic I'm guessing. Took vid and pix around the toilet but no stickers to find the model??
TIA Mike
Mike Gray
Forest River Wildwood
2017 27 RKSS
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 07-30-2023, 08:25 AM   #2
Kanadian Kamper
kenandterry's Avatar
Can you take a complete photo of the toilet, and maybe we can guesstimate what model you have.
Here’s the Dometic website……maybe you can see for yourself.
https://www.dometic.com/en-ca/outdoo...ion/rv-toilets
Ken and Terry
kenandterry is offline   Reply With Quote
Old 07-30-2023, 08:46 AM   #3
TIA Mike
Before you replace it, these toilets have a plastic 'ring' similar to the wax ring on residential toilets. They aren't very sturdy and occasionally need replacement.
If it's the valve, you should be able to feel moisture on the valve itself.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 07-30-2023, 09:06 AM   #4
Mike223's Avatar
No water around the valve just coming out from underneath the toilet. Maybe the flange needs replaced? Guessing it is a 300 model. Water stays in the bowl.
Mike
Mike Gray
2017 27 RKSS
Old 07-30-2023, 09:40 AM   #5
Mike
Oh dear. A 300 model.
Those are notorious for not flushing properly and keeping urine within the toilet plumbing until the smell gets overwhelming. A direct replacement is the 310 model which most people switch to.
So the flange is a definite possibility. We had to replace ours in our tt. Finding the correct flange was the hard part.
Old 07-30-2023, 10:33 AM   #6
Mike223's Avatar
I've decided to replace the flange, water valve and toilet seal valve just to be safe. Will have the toilet out anyway. Nothing but money as they with it say.
Mike
Mike Gray
2017 27 RKSS
Old 07-30-2023, 10:55 AM   #7
Mike
If it is the Dometic 300 model, the best solution is to remove the toilet, put it in the trash, and replace it with a Dometic 310. Problem solved.
The 300 model, all plastic, is noted to accumulate waste between the inner bowl and the outer base. It is nasty and will smell!
Wear gloves and a mask and eye protection. Remove it and toss it!
I know, I did exactly this and the result is VERY satisfactory.
Bob
Bob K4TAX is offline   Reply With Quote
Old 07-30-2023, 11:15 AM   #8
Mike223's Avatar
Hopefully when I pull it out I can find out what it is.
Thanks, Mike
Mike Gray
2017 27 RKSS
Old 07-30-2023, 12:01 PM   #9
Mike223's Avatar
It is model 300. Sticker under the foot pedal.
Mike Gray
2017 27 RKSS
Old 07-30-2023, 12:23 PM   #10
JWood422's Avatar
Whatever you decide to do, be sure and keep the bolts above the hole in the floor. They’re not easy to fish out.
JWood422 is offline   Reply With Quote
Old 07-30-2023, 02:46 PM   #11
Enjoying Life
Just replace the toilet. Even if you fix it now, it will happen again and again and...
2022 Rockwood 2109S
Previous: Rockwood 2608WS, 2608BSD
2006 Durango HEMI
TeachTexas is online now   Reply With Quote
dometic, leak, toilet
