Old 07-27-2021, 05:37 PM   #1
Draining Black Water at Seasonal Site
Hi Everyone!
We have a Chaparral 5th Wheel and since COVID hit have been stationary at a seasonal site in an RV park. A plumber told us always to leave the black water valve OPEN since we are not moving and hooked up to an outside holding tank at risk of sedimentation. Is this correct? I thought that the onboard holding tank (In the RV, that is) needs to have lots of water and a good "head" to move everything through, esp. solids. Any thoughts in this?
ross0547 is offline   Reply With Quote
Old 07-27-2021, 05:47 PM   #2
fonzie's Avatar
Keep valve close until ready to dump with plenty of water.
Fonzie
Old 07-27-2021, 05:51 PM   #3
The plumber would have most RV’s plugged solid in a week or two. Keep the tank closed until full, then dump it and reclose it.
I have a guy across the street from me who says he keeps his open all the time and it is fine. The only thing I can think of is that his drain is pretty much straight under the toilet so everything drops right down the drain line as soon as it is flushed, most campers won’t work that way.
2021 Coachmen Freedom Express 246RKS
2020 Ford Ranger
DougW is offline   Reply With Quote
Old 07-28-2021, 07:59 AM   #4
Plumber must also run a tank cleaning business.
South Bend Indiana
Rockwood, 2015 Ultra V 2715vs
05 gmc 2500HD Duramax/Allison
Happy Camper 2715 is offline   Reply With Quote
Old 07-28-2021, 08:20 AM   #5
Chuck_S's Avatar
Keep the black valve closed just like us weekend campers.
The plumber may be experienced with "mobile homes" but not "RVs."
Years ago I lived in a "mobile home" and, no surprise, there were no valves so all the waste water and sewage went directly to the sewer. Clogs were not an issue but (1) there was no waste tank in the trailer to slow things down, (2) the drain pipe was smooth inside, not corrugated, and a straight, angled shot to the sewer, and (3) there were flush toilets using a good quantity of water.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 07-28-2021, 08:34 AM   #6
FrankG's Avatar
When you are on site, dump as required. When leaving, dump and flush and add about 5 gal of water. In the freezing time of the year I dump in a couple of gallons of pink antifreeze, after dumping and flushing, to protect the plumbing and valve. This goes for the grey water tanks also.
Tale of the Redwood; For three seasons the snowbirds left the tank valves open. After it sat for a year, in place, the new owners quickly experienced a full plugged tank. The pile had moved. You know the rest of the story, the tank cleaners were summoned. And the story gets better, the original owner, a non citizen, never paid the tax or had it titled. The selling dealer moved it on site for the customer. The new owner was mailed a receipt and statement of origin. It took some time to get that one sorted out.
Good Day
2021 F-150 XLT with most of the goodies
2021 Surveyor Legend 19RBLE
2018 Haulin 6 x 12 Cargo Trailer by Forest River
2017 Laredo 325RL Sold
2016 Vengeance 29V Sold
1970 Yellowstone Used as downpayment for first house
FrankG is offline   Reply With Quote
Old 07-28-2021, 09:00 AM   #7
Don't forget to use a high quality treatment in the tank after each draining. I prefer an enzyme over a formaldehyde based treatment. And it would be wise to flush the tank occasionally after draining it.
Sunseeker16 is online now   Reply With Quote
Old 07-28-2021, 10:10 AM   #8
Brake is on left
The Evil Twin's Avatar
Have to generate business one way or another!
The Evil Twin is offline   Reply With Quote
Old 07-28-2021, 12:16 PM   #9
Dahagen
I spend 6 months sitting in Arizona with a lot of friends in an RV park. We ALL keep the black valve closed and the grey open. The day before the weekly dumping of the black we close the grey. Then on dump day open black, flush out if you can, close black and then open grey to help flush. On warmer days I put chemical pods in black after dumping.
dahagen is offline   Reply With Quote
Old 07-28-2021, 12:49 PM   #10
raysen's Avatar
That plumber is looking for business. I am a plumber and I keep my black tank valves closed until ready to dump.
raysen is offline   Reply With Quote
Old 07-28-2021, 12:58 PM   #11
Originally Posted by ross0547 View Post
Hi Everyone!
It is not!
As you eluded to and as was mentioned, even when seasonal and connected to sewer full time, a R/V toilet does not provide enough water with each flush to move the solids to the sewer system.
I hope you don't already have a poop pyramid at the bottom of your black tank.
The use of chemicals is dependent on how long you wait between times of emptying the black tank. Many folks who are seasonal but only weekenders and dump when leaving on Sunday do not use chemicals as the contents isn't in there long enough for chemicals to work or to present an issue. But... be sure to use lots of water when flushing the toilet and to at least somewhat fill the tank before dumping as both the toilet flushing process and the tank dumping process requires plenty of water to do the job correctly.
If your of the mind set to leave the black tank entirely fill with toilet flushes before emptying the tank, then that could take a month or more of weekend use. In those cases, most folks use a tank chemical of their choice.
In the end... remember it is a holding tank and not a septic tank.
Folks who are NOT connected to sewer and move between non-hook-up sites follow a bit different holding/dumping plan that most always involves chemicals since they typically don't dump until full and smell becomes an issue.
Days Camped: '18=51 '19=58 '20=110 '21=98
Old 07-28-2021, 01:40 PM   #12
I've been on a seasonal site many years and have always kept the black closed be between dumps with no issues what so ever.
traindrv is offline   Reply With Quote
Old 07-28-2021, 01:59 PM   #13
GravelRider's Avatar
So do you leave the grey tank valve open? When I camp with full hookups, I keep it closed, but only so that I can rinse out the black tank after I dump that.
GravelRider is offline   Reply With Quote
Old 07-29-2021, 01:03 PM   #14
Homebrew's Avatar
I agree with all about keeping the black tank valve closed.
But here’s a idea for seasonal camping. Change your manual valves to electric and install the switch inside. As long as you’re hard piped which most seasonal sites require then you have nothing to worry about, just push a button to dump your tanks while inside.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 07-29-2021, 01:07 PM   #15
wyodrums's Avatar
Our kids bought their first RV is year. Went to take it out the first time and noticed a poop pyramid in the tank. We are guessing the previous owner used it last at a full hook up park and left the black tank valve open. Yea, it was rough getting it cleaned out.
2021 Surveyor 203rkle
2018 Chevy Silverado
Fastway e2 Hitch
wyodrums is offline   Reply With Quote
Old 07-29-2021, 01:08 PM   #16
I don't know that I'd say "most".
2 of the 3 CGs I've been seasonal at didn't have sewer hookups in the site we were on.
1st one required the honey wagon every week. Current one requires a portable tote.
Iwritecode is offline   Reply With Quote
Old 07-29-2021, 01:32 PM   #17
Homebrew's Avatar
Ok agree if there is no sewer fitting , but I’ve been to 3-4 and had sewer hook ups and we were not permitted to use flexible sewer hoses unless we were dumping. Then the hose had to be removed and put away.
I guess they didn’t want animals to damage it or the sun to break down the flexible hose.
All I know is that I had to purchase pipe,fittings, glue and order the bayonet fitting online to connect to the RV for a 6 month stay.
2014 Ram 3500 DRW
Old 07-31-2021, 12:41 AM   #18
Another adventure awaits!
HESN22's Avatar
We leave our black water and bathroom grey water closed ... flush our system weekly or more often if needed ... black tank first, then grey to clean out the lines ...
Both dealerships we bought our 5ths from have advised this, including campground owners.
Dont know anyone here, seasonal park, that doesn't do it this way.
HESN22 is offline   Reply With Quote
Old 07-31-2021, 12:47 AM   #19
HESN22's Avatar
Homebrew this is for you
Switch inside? ElectrIc? You have my attention ... any links for this, please ....
I would love to do have this option ... I'm here most of the time by myself and sometimes have to end up dumping tanks; try to wait til hubby is here, but sometimes, just can't.
Thank you in advance .
2018 Columbus Compass 377MBC
2013 F250 4 x 4 Supercab
Old 07-31-2021, 06:19 AM   #20
Homebrew's Avatar
Sent you a pm with a link.
2014 Ram 3500 DRW
black, black water, drain, water
