Originally Posted by fwschreiber
Are there any diagrams on line showing where Forest River puts low-point drain valves on a Flagstaff 22FBS? The PDFs I've found so far are useless. Even if I just knew how many there are, I'd know if I've found them all.
Usually there are three drains: hot and cold water drains and fresh water tank drain. They are located at the fresh water tank input at bottom and usually the hot and cold system drains are located together at the rear of the trailer. one should be on a red pex pipe and the other on a blue pex pipe. You can't miss them.
Your trailer appears to be a clone of my Coachman.
