Originally Posted by Chiara
I have a Forest River Wildwood DL 40FDEN. I would like to know how to drain my fresh water tank without having to run the pump to drain it thru the faucets. There is a sticker that says "Low Point Drain" and a white valve close to the tank but I'm not sure that's it. Any assistance would be much appreciated.
Chiara
It's too bad you didn't get a chance to video record your walk-through.
Low point drain(s) are for draining the water out of lines/pipes inside a unit. One is usually blue for cold water; on is usually red for hot water. They are not for draining the fresh water tank. Generally (note this word), the fresh water tank drain is under the tank itself. You generally have to get down and look under the unit under the tank to find it.
