06-11-2018, 09:03 AM
#21
Originally Posted by JohnD10
But it won't drain out the crud floating on the top of the water in the heater...
And it won't release the air bubbles, either.
But it WILL release the pressure, which is what you're trying to accomplish so the water doesn't spray out later. (Don't know what air bubbles or crud have to do with relieving the pressure. Pretty sure the PRV is below the surface of the water - faster pressure drop with water flow than with air flow, since water is incompressible.)
Originally Posted by RacerRalph
Before you remove the anode, use the pressure relief valve to relieve the tank pressure. Guess how I learned about that step!!
Of course, if you're removing the anode, the PRV is right there; no need to go inside to open a faucet.
2011 Traverse LT, 3.6L, FWD
06-28-2018, 07:55 PM
#22
PRV
Does opening the PRV ruin the valve? My FIL told me not to crack mine as it would mess it up.
06-28-2018, 08:59 PM
#23
They tell you to use it as necessary to restore the air bubble in the water heater. See page 20.
06-28-2018, 09:49 PM
#24
Denver To Yuma In 90 Days
It wouldn't be there if it wasn't meant to be used...
Not only do I use it to release the air bubbles, but also to release the crud that accumulates in the hot water tank, which generally floats to the top!
06-28-2018, 10:56 PM
#25
PRV
I’m guessing he thought it was more of a pop off valve and wouldn’t reseal. Thanks for the reply’s. I’m new to the camper world.
06-29-2018, 11:08 AM
#26
Yep I open up my valve to drain the tank after every trip. We’ve discovered the horrid rotten egg smell comes if we leave water in the fresh tank and water heater for even a few weeks in the summer between outings.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
06-29-2018, 11:16 AM
#27
Sorry to disagree, but most of the crud settles to the bottom and can be removed by removing the anode on a Suburban or the plastic plug on an Atwood.
06-29-2018, 11:48 AM
#28
Yes, but some of it does go to the top and when you are long-terming in your RV this is one way to bleed off some of the crud without having to wait for the water heater to cool down completely to drain it.
It does work!
