03-15-2022, 07:00 AM
Dropped ring in toilet
Any suggestions for domestic toilet?
03-15-2022, 07:18 AM
Depends on the value of the ring and when did you last empty it. 5 gallon buckets one at a time if it's really valuable.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
03-15-2022, 07:51 AM
The bucket idea is a good one, also keep in mind the ring might stay in the tank when you drain it and you may have to leave the dump valve open and flush the tank to rinse it out and I wouldn’t be surprised if you have to use one of the through the toilet flush wands to get it out of there.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
03-15-2022, 08:01 AM
How full is the black tank?
As mentioned, 5 gallon buckets to dump into and then check each time.
If it stays in the tank after emptying, an inexpensive (<$20) endoscope for a cell phone will tell you where it is. Some even come with hooks to snare it.
03-20-2022, 07:04 PM
Wonder if we will ever find out?
2019 FR Rockwood Mini Lite 2109S
2022 RAM 1500 Bighorn, Quad Cab, 5.7 Hemi, 3.92 gears
To get better, you have to get better at what you are doing to get better.
03-20-2022, 07:17 PM
OP logged off 24 minutes after initiating the thread (probably about a Dometic toilet) and hasn't logged back on.
03-20-2022, 07:41 PM
How would that happen? Loose ring maybe and wiping too hard? Weird!
Edit: why Dometic?
03-20-2022, 07:54 PM
Edit: why Dometic?
Doesn't say Dometic. Op said domestic. Might have meant Dometic but said domestic. Gotta take them at their word right.
Call a plumber and open the wallet.
Rockwood Geo-Pro 15TB on order
2019 Ford Ranger
03-20-2022, 09:04 PM
Much like the number of licks it takes to get to the center of a tootsie pop...
The world may never know,
03-20-2022, 09:35 PM
And maybe it was not a ring like in jewelry… maybe it was the seal ring around the ball… will never know if op never comes back..
03-20-2022, 09:42 PM
I hate it when someone comes on here for advice and never replys back with results.
03-20-2022, 10:02 PM
Me too!
03-20-2022, 10:20 PM
x3
2019 Ford Ranger
03-21-2022, 08:48 AM
Welcome to the world of Internet Forums.
