Old 06-10-2020, 09:25 PM   #1
Dumb newbie question
I have a 2020 MB’s 2400q sunseeker with an outdoor shower which is basically a coil hose with a quick connect an a garden nozzle. How dose the thing work I have the water pump on an hose connected and just a dribble, can’t find any valves took the nozzle off still nothing. Does it only work when hooked to city water? Thanks
Bigfoot11 is offline   Reply With Quote
Old 06-10-2020, 10:51 PM   #2
Look for the shutoff switch on the wand. It will provide a dribble when off and spray when on.
darb is offline   Reply With Quote
Old 06-10-2020, 11:25 PM   #3
CincyGus's Avatar
Are you sure you are talking about the outdoor shower? Most outdoor showers have what looks like a bathroom sink faucet with a hot and cold water knobs and a single non coiled hose come off with a shower wand like what is inside in the shower.
What your describing sounds like a spay port that some campers have as an additional outside water source that is cold water only and for rinsing off bikes, ATV's, etc.
Check the rest of your compartment doors on the drivers side of the trailer and I'll bet you find a true outdoor shower like I describe.
That said, Make sure you have the coiled hose fully inserted into the quick connect fitting by taking it out and putting it in a few times and then trying again. It should work with either city water or pump pressure. If not, you should contact your dealer as it would be a warranty issue.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
newbie
