Originally Posted by Road King Russ
We are out on the shakedown cruise with our new Microlite 22FBS. The water heater will not run in the electric mode. It runs fine on gas. All other 110 appliances are working fine. Any suggestions on how to troubleshoot it. The manual is worthless. Thanks!
Give us the model number of the water heater.
Do you know it doesn't run or is the problem that no hot water comes out any hot faucet?
Have you located and turned on the electric element switch on the lower left corner of the heater inside the outside heater vent cover?
Is your heater breaker turned on inside your power center cover?
If those questions don't solve the issue, you'll need to find the outlet where the heater plugs in (is it plugged in?) and determine if that outlet is receiving power.
