I'm guessing you are speaking about a spray port quick connection. My Cedar Creek has one by the entry door too that's designed to spray off the Morryde steps.
There is no shutoff to the port but it may have some debris in the quick connect. If you have access to the back side of it via a pass through or access door, you could remove the fitting on the back (once water pressure is relieved) and have a look.
