Sounds like the standard PEX clamp and crimp connectors. They make a tool to crimp new bands on if you are so inclined.
I always cut off the PEX crimp bands and replace them with Sharkbyte push to connect fittings. Much easier and reusable as well.
For low point drain lines, I cut off the crimped band fittings and replace with a male pipe thread Sharkbyte fitting and then screw on a PVC quarter turn shut off valve.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
