Originally Posted by reubenray374
My lock will not work in this and I got a replacement and it will not work either. The locks spin in the opening in the thin piece of plastic.
Has anyone put another type of latch on this? It does not need to be lockable.
This kind?
They come in various lengths, depending on your door thickness. The threaded part has flats on two sides which is supposed to prevent the body from rotating. If the lock is stiff and has been forced, the flats on the mounting hole will have been rounded off. You might be able to tighten the nut enough to prevent rotation.
Be sure to measure the present lock before ordering, to get the right length. You can use the flat tongue that comes with it, or the offset tongue in either of two position to get a little bit of adjustment.
You can get keyed or unkeyed locks from many places including eBay, Amazon, and all the RV supply places.
