03-09-2020, 11:27 PM
#41
Because the supports they come with are inadequate. This is an ongoing saga with many trailers.
Originally Posted by desuhu
Why would you need to shore up the fresh water tank on a new RV? It should be re-enforced from the factory. It's on there to use, so why isn't it fixed right in the first place.
#42
GuitarPlayerBP
Fill at Home
I’m with many others. I fill mine at home. I have water for the trip and I know it’s good water. If my wife or I need to take a break we have water to flush.
03-09-2020, 11:43 PM
#43
Camping 101 says find a site with water. I've camped many places with no hookups and just filled the RV tank with multiple trips and a 5 gallon jug I carry for that purpose. I agree all RVs SHOULD be designed to travel with a full water tank; but sadly not all are and we usually find out after the purchase.
2015 Flagstaff 21FBRS
2012 Silverado 1500 LT Ext Cab 5.3L 3.08
Blue Ox SwayPro 550
03-10-2020, 08:17 AM
#44
Sunseeker 2400MBW
We like to travel with just enough freshwater to use the facilities on the way. People have their preferences and that’s ok.
We use iOverlander app, it lists everything you can think of. Allstays is older, I guess there might be more information.
It is surprising to me how many places just let you fill up for free. We use our own hose with the blue camco filter installed.
used to be - Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester. 2021 we bought a house.....Still have the precious Sunseeker and tow car.
03-10-2020, 08:43 AM
#45
Take it easy,but take it
Traveling with water
I see your question is where to get water-We do a lot of checking around the area we want to camp at-KOA always has water .Kind of expensive, but so what. Also you can dump there on your way out $..And if you have several water containers (10 gal each) fill those and take with you-I made a water pump transfer unit from an old rv water pump,and you can pump that 10-20 gallons in with when you get to you destination.Also if there is water at the site ,you can fill you containers and pump once you get there..Dont hesitate to put 15-20 gallons in your camper before you go .It will be safe.Anything more in a FR would probably be a problem-I bowed my brackets. Call forest service office's in the area you want to camp, and they can tell you where water is avail.
03-10-2020, 09:09 AM
#46
... because probably north of 25% of us have had weak "reinforced tank supports" from the factory buckle under weigh. In my case it was not from hauling water on a trip but from filing my tank to sanitize it after a trip.
03-10-2020, 09:46 AM
#47
I feel the same and have the same problem. Too much weight and poor supports.
We are in month 3 of traveling the south and there have been a few times we are heading to primitive site or even Walmart for the night and need water in the fresh water tank.
We’ve stopped at many gas stations to find they do not offer fresh water. If they do, faucet is in front and cannot connect our hose. I have filled our 5 gal water container a few times in a pinch.
Here’s what I do. Whenever avail, I put 5 to 10 gals into my 30 gal tank and travel with that. This way, at least I have enough to flush the toilet!
Also, keep that 5 gal container full.! We have used it to simply rinse the toilet and use for coffee. Bottled water for drinking. Simple.
David & Cindy in Iowa
2017 RockWood 2504S travel trailer
2015 Chevy Silverado 1500 LTZ
03-10-2020, 02:20 PM
#48
Well, with your water supply problem you are pretty well alone! Unless you list the places you go to!
We trust anybody that lets us fill up. But asking on site helps as the company knows the quality of their water. Once you figured out a location of each of your destinations you can go back to them!
We generally do not drink out of our tanks as the water may taste bad (we are pretty snobby with that) and use bottled water to drink. Anything that is boiled before use is OK. We also fill our tank about 50% at home to have water while we get there and look for water, and can last a long time on that if the supply is tight.
03-10-2020, 02:46 PM
#49
Trailer Park Supervisor
Water that tastes or smells bad does not go in my tank. I sample first. If it's not delicious out of my taps, it doesn't go in tanks. I REFUSE to BUY water and the wasteful plastic containers.
Yes, I drink the water!
03-10-2020, 02:56 PM
#50
I totally agree. Which makes me crazy why there is a run on bottled water right now. I have no problem drinking the tap water in my house.
We always fill up a 7 gallon aquatainer before we leave on a trip. It travels in the shower and gets set up on the picnic bench. That is plenty of drinking water for the trip. I actually don't mind drinking the water we fill from home in our fresh water tank. It has a slight more plastic taste but really not that bad.
03-10-2020, 02:58 PM
#51
AMEN!
03-10-2020, 03:24 PM
#52
Scoundrel
Bottled water companies don't make water. They make plastic. Specifically single use plastic.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
03-10-2020, 03:51 PM
#53
#! - Wherever I fill my water tank I use MY fresh water hose.
#2 - Wherever I fill my water tank I run it through a Camco water filter attached to the end of the hose hose.I also use that filter for "hookup water".
Andy & Kim
Mimi & Jojo - Kamping Kitties
2018 Sunseeker 2290S
03-10-2020, 04:11 PM
#54
Sunseeker 2400MBW
We live in our MH. There is no “water from home”. We find most everywhere is pretty good, my hometown is terrible tasting.
We also have a five gallon container we use sometimes. I’m shocked at how well that flimsy looking container has held up.
03-10-2020, 07:49 PM
#55
MANY of the 16 oz or 500ml bottles used by bottled water companies are made in China. They can make, label and ship them here for about 3 cents a bottle where US products run closer to 15 cents per - or that's the way it was about ten years ago.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
03-15-2020, 10:21 AM
#56
As for a manufacturer advising against towing with full tank of water, sounds to me like they are admitting to a design deficiency in their product.
As to filling up at Truck Stops, they are chaotic at best and I can only imagine the risk towing in those tight confines. Is saving a few pennies by reducing weight really worth it?
03-16-2020, 12:39 PM
#57
Originally Posted by jdonahue805
Hello Everyone,
I just got my first TT, a GeoPro 15TB. My question is pretty basic. I prefer to travel with an empty fresh water tank until I get to my site. However, many of the places I go are primitive with no water. So I want to fill my tank when I get close to where I'll be staying. I'm looking for suggestions on where to fill up my tank. I thought about gas stations, but I wonder if the hoses they use are fresh water "okay." Any suggestions of stores, other public places to fill up with potable water before heading to my primitive camp site. I'm thinking of places along an interstate, or prior to getting to the more primitive areas. Anyone know of an app that has this info?
Thanks,
Joe
Consider taking your own fresh water hose along: I won't use my garden hose at home to fill my tank - I use my fresh water hose. I let the water run through the hose for a couple of minutes to flush it. I also use a filter. Most campgrounds have a water fill station.
03-16-2020, 12:44 PM
#58
Thank you
Thanks to everyone for your thoughts. I've checked with Forest River and here's their reply:
The tank supports will easily hold a full tank, but we do not recommend traveling with full tanks because the force realized if/when you hit a rough patch of road multiplies and it could bend a support bracket. We recommend taking enough water to get to your destination and then filling your tank as stated in our Owner’s Manual.
So, there you go!!
03-16-2020, 12:53 PM
#59
Yep... there you go... they are covering their butts.
I will never own a R/V that I could not travel with a full tank of fresh water.
It defeats the entire premise of a mobile, recreational vehicle.
03-16-2020, 01:22 PM
#60
x2! We dry camp a lot and prefer our own water for as long as it lasts.
