09-30-2018, 07:26 PM
First flush
New 5th wheel. First attempt black tank flush. Connected sewer line, Hooked water into flush inlet pulled black tank valve to open, turned on water- nothing happened. What am i doing wrong?
09-30-2018, 07:41 PM
Certified Curmudgeon
Nothing? No water spraying into tank? No tank content discharge?
Mike Dropped
That's the correct procedure. Sometimes it takes a minute or two to see the water flowing out the black tank valve. Do you have a clear elbow that you can see the water flowing out?
2015 Dynamax REV 24TB class C
09-30-2018, 08:02 PM
Yes o have a clear elbow and don’t see any flow. I thought maybe i was missing something
09-30-2018, 08:10 PM
Thats not good. Was your black tank empty and youre just trying the flusher?
Mike Dropped
09-30-2018, 08:49 PM
Yes
09-30-2018, 09:13 PM
Ok Thats good, real good.
A few things to try:
Make sure the tank valve is opening. If you have a cable pull from a docking station to the valve, it may just be disconnect. (Assembly error)
Next is the old cut out stuck in the drain before the valve. You can try to run a hose up the dump pipe into the tank.
Then there is the second valve possibility. Some units have a “final” valve near where the dump exits. This is in case there is a leak in the primary or the primary inadvertently opens.
And the last (or first) thing to check is that the plug in the coupling end of the hose is removed. This applies only to WasteMaster systems.
And I know how this may sound but Is the water on at the hose bib?
Good Luck & Hope this helps.
Ducky
Mike Dropped
09-30-2018, 09:55 PM
Many units have a vacuum breaker or check valve in the flush line. It's usually located under the bathroom sink; it will always be mounted higher than the tank. Usually looks like this:
Here's a diagram of how it's hooked up.
Sometimes they get installed backwards, so they don't allow flow.
2011 Traverse LT, 3.6L, FWD
09-30-2018, 10:15 PM
Thanks. I ll try again in morning . Unit is brand new and black tank has neen dumping correctly evert time
10-01-2018, 11:17 AM
Check valve was installed backwards from factory
10-01-2018, 11:46 AM
Not uncommon. Glad you got it figured out.
10-01-2018, 12:55 PM
X2
10-01-2018, 06:46 PM
X3 Good call RFDRoo
Mike Dropped
