First Time Winterizing
Heya,
I’m going to have a go at winterizing and have a couple of questions.
I have antifreeze but don’t seem to have a hose connection on my water pump, as in the picture. However, I do have two connectors on the ends of the pipes near my hot water heater. Can either of those have a winterizing hose attached to it?
Also, the simplest method without the hose would be for me to dump antifreeze in the fresh water tank and pump it from there. I’ve read that it’s totally ok and the go-to method for a lot of people and then read that it’s no good and takes several flushes of your FW tank to get rid of bad taste in the spring. What are your thoughts?
EDIT: I've got room under there, so I've ordered the Camco pump converter kit anway, but still curious about the antifreeze in the tank vs. bypass thoughts.
Thanks!
