Flagstaff water pump won't pressurize system
I believe I have Isolated the problem. The pump is having trouble pulling from the fresh tank. I disconnected the line in to the pump and replaced it with a line going directly to a 2-1/2 gallon jug of water. Everything behaves as it should. There must be a bad connection at the tank, or a split in the line somewhere, although I have never seen and dripping under the camper. There appears to be a removable panel under the tank which I how will allow access. Is anybody aware of any check valves, etc. that I might run into?
