flat pump suction
Wondering if any one has experienced this problem. I have a 2021 Heartland, Fuel, toyhauler, F-250. During the last freeze here in Texas I disconnected the park water and was going to rely on the on-board tank. The pump ran but did not pump water. Long story short have water after the freeze but discovered the pump suction hose is flat. Pump works fine. To replace the hose I'll have to remove the enclosed under belly material and find the tank and do whatever needs to be done to replace the hose. Of course will have to drain the tank before I start just don't understand why the hose is still flat.
Any thoughts?
