Old 11-03-2016, 08:44 PM   #1
Flushing water heater
I'm wanting to flush deposits out of the water heater. I have the anode pulled, city water hooked up, turned on and all faucets turned off, so can someone tell why no water is coming out of anode fitting.
Dan and Marty
2wired is offline   Reply With Quote
Old 11-03-2016, 08:52 PM   #2
tom39's Avatar
Is your WH bi-pass valve turned on?
2011 Rockwood 8288 SS UL
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
tom39 is online now   Reply With Quote
Old 11-03-2016, 08:55 PM   #3
I believe you'd be better off flushing the deposits through the anode rod hole with a a jet type nozzle on your garden hose....
SidecarFlip is offline   Reply With Quote
Old 11-03-2016, 08:55 PM   #4
Mr. Dan's Avatar
I'd guess you have your valves set to winterizing configuration or at least one of them. One of those valves keeps water from going into the heater.
That said, I agree with SidecarFlip. Flush with water going into the anode port.
Dan & Marty here, too!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 11-03-2016, 08:57 PM   #5
Flybob's Avatar
WH bypassed. Most people flush the WH via the anode rod. There are some inexpensive spray wands to stick in the anode rod hole and spray the inside of the tank. The advantage of this is little or no crud gets in your water lines to clog faucets.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-03-2016, 09:02 PM   #6
What I did with mine this fall is I pulled the anode rod and tool my pressure washer with a narrow nozzle and stuck it in the anode hole. That cleaned it right out, right now.
I guess the anode rod flakes off and winds up on the bottom of the tank....
Got a new rod from Amazon too.
Old 11-03-2016, 09:04 PM   #7
BooBoo23's Avatar
You need one of these, made by camco. You can get them from Amazon, any camper dealer or even Home Depot (less than $7). P/N 11691
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 11-03-2016, 09:07 PM   #8
Thanks for the info
Right after I posted the question, I found some info on here. Thanks for all the replies.
Dan
Old 11-03-2016, 09:09 PM   #9
Flybob's Avatar
When you order your anode rod, get two. They are inexpensive and that way next time you need one you don't have to wait or make a special trip to a dealer.
TST Tire Monitors
2 100W solar panels
Old 11-03-2016, 09:33 PM   #10
A used Washing machine water hose cut in 1/2 "they are Free from any Appliance dealer" inserted in the A-Rod hole will "Whip around inside the W/H tank and flush out the White Crud" Just attach to garden hose,a large bottle brush helps at the same time! PS give the other 1/2 of hose to a RV buddy! Youroo!!
Old 11-03-2016, 10:13 PM   #11
Stupid newb question - why does the WH need flushing? What gets in there that shouldn't be there? Calcium deposits? Sacrificial bits of the a-rod?
2012 Sunseeker 2250S/2008 Yamaha Venture (1300 cc V-Four)
rebellee is offline   Reply With Quote
Old 11-03-2016, 10:45 PM   #12
The first time you drain your WH you will know what gets in there. Yes, it's basically calcium and other mineral deposits. I just drain mine, then stick my garden spray nozzle up to the hole and shoot the water in until it won't go in anymore, then let drain again. I do this a few times. So far, I have not felt the need to do more.
Others use the wand as discussed in the posts above.
Some people actually put 3-4 gal of vinegar in and turn it on for a few hours. This dissolves a lot of the crud. If you google "RV water heater vinegar," there are some videos of this out there.
What you do may depend on how much you use your TT and what you think the quality of the water you're using is.
2011 Traverse LT, 3.6L, FWD
Old 11-03-2016, 11:12 PM   #13
BooBoo23's Avatar
Your next newb question will be "I can't get my kitchen faucet to work" and the repair will be clean the crud from the WH out of the aerator on the faucet.
KT4W
heater, water, water heater
