Try putting some of your toilet chemicals/deodorizer in your sink and let it go into your gray tank. Are you leaving the gray tank valve open while you camp? If so, you are allowing the "stink gasses" from the sewer to get inside your trailer. Is there water in the p traps?
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
