Old 07-29-2020, 10:42 AM   #1
FR Flagstaff fresh water drain assembly
I was wondering if anyone on this forum has had problems with the outside fresh water tank drain assembly? I say assembly because the drain it self has a black plastic cover/shield that is attached to the underbelly of the trailer with four screws. Two screws into the plastic under belly and two screws into the frame. The plastic around screws where it is screwed to the frame is cracked/broken, therefore, the drain is dangling down and now being held with only two screws. It needs to be repaired or replaced. I cannot find a replacement. Looking for suggestions on repair or replacement. I‘m guessing with all my trips to Florida and Tennessee the normal bouncing on the road has broken the plastic. Probably not engineered well on this portion.
Any help is appreciated
2016 Forest River Flagstaff
27ft Travel Trailer.
rduri is offline   Reply With Quote
Old 07-29-2020, 10:47 AM   #2
A photo would help.
FR used many different types of drains.
Does it look something like this?
Many folks have modified them for whatever reasons.
Days Camped: '18=51 '19=58 '20=110 '21=47
Old 07-29-2020, 10:52 AM   #3
The top picture
drain, forest river, fresh water, water
