Originally Posted by dpwitch
I don't have the water heater literature with me right now but I looked at your link and I do know I have 3 buttons related to water; water heater, water pump, tank heater. I'll post tomorrow when I stop by the RV and verify a couple of things. Thank you.
OK Great. What I run into a lot with new RV owners or ones not familiar with a Suburban SWDE operation, is the electric heating element switch on the face of the water heater.
If you have this type, but don't know about that switch, then every time you plug into a form of 120 volt AC shore power/generator, then the electric heating element instantly starts heating the water that way.
Some RV'ers get hot water and mistakingly think that the RV automatically is heating the water, not realizing that switch is ON, cause they don't even know it's there.
If you just have ONE inside switch to the water heater, it is to the propane mode. But you have to have the propane tanks open and filled with propane to use that mode and switch.
My thoughts is you may have turned on the inside switch to the propane, but it may not be coming on or even heating the water if you you don't have the cylinders open or purged of air. Your heated water came from the electric heating element mode, which you may not even know was on if you do have the Suburban SWDE. The electric heating element does heat water slower than the propane side (but 2 hours should have been enough to reheat a tank)
This is why I have been trying to find out your model and mode of user operation.
