Old 10-05-2020, 12:07 AM   #1
Fresh tank drain improvement
My 2020 Rockwood has a 1.25" gate valve to drain the fresh tank. It's a huge improvement over the old screw-in plug but I just saw a 2021 model which is improved even more. Instead of having the valve at the bottom of the tank 3' in from the side, they put a 90° elbow there, extended the drain to the side of the trailer, and put the gate valve there. It looks much more convenient.
I haven't looked to see if the drain pipe is glued or threaded. If threaded, I'll be doing the same myself this week. I may do it if it's glued but it has to have enough excess pipe to glue the elbow to after cutting it off.
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
drain, tank
