Old 05-13-2017, 10:17 AM   #1
Fresh tank leaking when filling
When filling up my Sabre 25RULD fresh water tank when full it leaks onto my underbelly it doesn't come out my air vent I'm guessing the vent hose came off whats the easiest way to get at that tank without taking everything apart thanks
Hnatyshyn is offline   Reply With Quote
Old 05-13-2017, 10:35 AM   #2
The only 'easy' way is to cut the coroplast in the suspect area but then you have to deal with sealing where you cut it. Not a big deal but no matter what, it's compromised.
Best bet... pull the coroplast down.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 05-14-2017, 10:20 PM   #3
what do you think the vent tube come off to bad their wasn't a good tank diagram to make a proper hole to make a repair
Old 05-14-2017, 10:46 PM   #4
Ours used to leak a little when we filled it.. I cut the underskin enough to get my hand up to the clamp and tightened the hose clamps on both the fill and the vent. The fill one was fairly loose. No leaks since...
To seal my cuts I used Gorilla Tape.. It seems to be doing a good job after a year..
Camped: 2020 (Days/Nights) - 7/5
2019 (D/N):27/20, 2018(D/N):24/17, 2017 (D/N):30/25, 2016 (D/N):32/23
TT: 2013 26' Revere TBQB
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 05-14-2017, 10:52 PM   #5
i don't have any water coming back through my vent tube even when its full I'm guessing the fill hose is about a foot long to the tank
Old 05-20-2017, 12:36 PM   #6
My experience x2
1 3/8" fill hose had cracks in it and the hose does NOT have a smooth surface. Tightening the clamps did not help. Wrong hose for the application.
The other camper hose had a kink at the fitting from over tightening.
mfMcFroggierPod is offline   Reply With Quote
Old 05-20-2017, 06:59 PM   #7
sgtlm17's Avatar
If you do cut the coroplast eternabond tape (although made for roofs) will repair it forever.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
leak, tank
