Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-29-2021, 08:14 PM   #1
Fresh water confusion
I have a confusing event happening when I hook up my TT to water.
When I hook up to water at camp sites,
Water flows through lines correctly,
but also fills up my potable water tank at the same time? I looked for a check valve on my water pump lines and I'm unable to locate one.
Could it be internal on the pump and have failed ?
Or is it supposed to fill up when connected?
Tazmiki is offline   Reply With Quote
Old 11-29-2021, 08:23 PM   #2
multiple threads a week about this. Check valve in pump is stuck open. turn off the water and run the pump.
Kimber45 is offline   Reply With Quote
Old 11-29-2021, 08:25 PM   #3
Disconnect from city water, run the fresh water pump several times. See if that clears the internal check valve.
NavyLCDR is offline   Reply With Quote
Old 11-29-2021, 11:55 PM   #4
Ok so there is an internal check valve then?
If remaining stuck open, then replace the pump perhaps ?
Am I able to add an external checkvalve to it ?
Old 11-29-2021, 11:59 PM   #5
If you have a shower miser, it could be that as well.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is online now   Reply With Quote
Old 12-02-2021, 08:29 PM   #6
larry2c's Avatar
There is a check valve - that is what LCDR & Kimber were talking about. FWIW, if you leave your water pump turned on while hooked up to city water connection, it can cause the check valve to not work properly and your FW tank will eventually fill up (it's happened to me a couple times). The instruction for shutting off the city water supply and then cycling the 12V pump will frequently reseat the check valve. Then don't forget to turn off the pump before turning the city water supply back on.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 12-02-2021, 09:49 PM   #7
1. Yes, built into the head of the pump.
2. You can, many have luck with the reseating process or disassembling the pump if it is debris.
3. Yes, an inline, external check valve has been added by many. Some have even installed 1/4 turn, manual shut off valves.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=27
Old 12-03-2021, 04:35 AM   #8
Openroadorer99's Avatar
I ended up just cutting in a shut off, to not chance back filling the fresh tank, as it seemed to have a mind of its own, even after taking the pump apart a few times. Works fine on pump only when turned back on. i am mostly connected to city water, so the shut off stays off unless use for traveling. Some never have a problem, mine started when i had a place with high psi, even with a regulator.
on the road
Openroadorer99 is offline   Reply With Quote
Old 12-03-2021, 12:19 PM   #9
Water pumps are almost always repairable if not leaking water (cracked housing) and motor runs.
Kits are available and rather inexpensive so if that is a concern it might be good to find pump model #, purchase a rebuild kit, and keep on hand.
If you have the kit on hand chances are you'll never have a problem in the future
BTW: if the pump is a Shurflo 4008 a complete repair kit, including check valve, is only $12.50 (Walmart.com).
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-04-2021, 03:30 PM   #10
Thank You
I'll need to see which one I have ,
Greatly Appreciated.
Old 12-04-2021, 04:48 PM   #11
That seems to be the best way to ensure you never have a problem with a component, buy and carry a spare one.
fresh water, water
