Fresh water drain Tee
On my 2010 1809s, the water supply hose on the fresh water tank, is not on the bottom. It’s approximately 2 inches up the side of the tank, so when the water level gets down to below 1/3 full, it begins sucking air. One recommendation on another post was to cap off the existing supply line access point, and put a T fitting on the drain fitting, so it can be both a supply line and drain point. Has anyone successfully done this? If so, pics and explanation would be awesome! Thank you.
