Old 06-02-2020, 11:59 AM   #1
Fresh water gauge
We have a brand new 2020 XLR that I am having trouble with the fresh water gauge. I have filled the water tank up completely so as to the point where it is spilling out and the gauge reads full. By the time I get to my Destiination, the gauge reads 1/3 full. I am not losing any water along the way so I am not sure how to troubleshoot this issueHas anyone else had trouble with a problem similar to this and if so how was it resolved?
Mew0050 is offline   Reply With Quote
Old 06-02-2020, 07:06 PM   #2
A32Deuce's Avatar
You may very well have the water being pulled from the overflow. Depending on how deep it goes into the tank, once it starts it will drain to that point and you won't see it coming out. You could cap or put a valve on the overflow/vent, but must remember to open on arrival or you will collapse the tank.
A32Deuce is offline   Reply With Quote
Old 06-02-2020, 07:30 PM   #3
Just as confused as you
Scrapper's Avatar
Even for fresh water those gauge lights are not the most reliable.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 06-04-2020, 12:26 PM   #4
Alpha2020's Avatar
Are you level when youíre filling?
Did you run the pump When you got to your destination? That would pull front the tank and affect your reading.
Also, like it was already said... the gauges are not SUPER reliable.
Alpha2020 is offline   Reply With Quote
Old 06-04-2020, 12:40 PM   #5
llr
Find water near you destination and fill the tank again. If it overflows almost immediately it is just a gauge issue. If it takes a lot of water then it is probably being siphoned out going down the road, a number of people on here have that issue.
I have a control panel with membrane switches of many functions and the gauges. It is terrible. I filled the fresh water the other day and it is reading 1/4 or less. I have had both the panel and relay box replaced twice, worthless.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
fresh water, water
