I see this is your first post - welcome!
Most likely the two are not likely connected (but that's just an uneducated opinion).
1. Fresh water tank filling while on city water = (most likely) stuck check valve. This is a common problem. The 'fix' is to exercise the check valve (open and close it repeatedly), by: first using one method (city water), then turning OFF city water, turning ON water pump and running some water. Switch sources and repeat (turn OFF pump, turn ON city water, run a faucet). Repeat this a few times. Every time you "switch sources" you're changing the side that the check valve sees pressure (so it opens and closes, like exercise). This puts pressure on either side of the check valve in alternating waves, eventually (hopefully) reseating it and allowing it to work properly again. Next step is to replace the check valve, but this usually fixes it.
2. Is running out of hot water a NEW problem, or simply new-to-this-rig? It sounds like (a) your Hot Water Heater is either not getting hot enough; (b) you're got cold water mixing into your hot earlier in the loop than at the shower head or (c) you're taking long showers. Different answers to the first question will direct the followups (though it seems like you USED to be able to get by, but something new is happening or has happened). The causes for (a) could be anything from "it's colder outside" to "your HWH thermostat needs to be replaced."
A. Make sure all faucets are turned off at faucet/with faucet knobs (including outside shower) - Not just stopped by handheld check valve.
B. Confirm that all your plumbing valves are properly set (in particular, hot water heater bypass valves)
C. Might be that you have to replace the thermostat on your Hot Water Heater - these DO go bad.
D. Lastly (and this is a sort of Hail Mary to limp along), try running on propane AND electric. This seems to give us an almost endless supply of hot water with FAST recovery time (so much so that we can take Hollywood showers with our 6-gal Hot Water Heater, instead of Navy showers).
Any response to guide us? (also, what's the brand and model of your hot water heater? This is always good info with which to start.)
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
