Old 07-29-2020, 11:47 AM   #1
ipb
Fresh water still remains in tank
I have a 19ft Coachmen "Freedom Express". My fresh water tank holds 49 gallons however it always seems to have around 5 gallons left after the pump runs "dry". Is this normal?
ipb is offline   Reply With Quote
Old 07-29-2020, 12:15 PM   #2
007matman's Avatar
I've never been able to measure how much is left in there but yes, it is somewhat normal for water to remain in there.
You could try parking on an angle so that the drain is lower. The only camper I've ever been able to drain everything out of was my pop-up and that was accomplished with a set of automotive ramps.
007matman is offline   Reply With Quote
Old 07-29-2020, 12:39 PM   #3
ipb
I knew there was quite a bit left in the tank so when I drained the tank from the drainhole underneath, I saved the water into a container so I could measure it. I know there will always be some water left but 10% seemed like a little too much.
Old 07-29-2020, 12:49 PM   #4
Install a tee/shut off valve to the drain, move the supply line to the tee you'll be able to use all the water in the tank that way.
latner is offline   Reply With Quote
Old 07-29-2020, 12:56 PM   #5
PhD, Common Sense
It is likely a design feature that the pump does not pump from the very bottom. You donít want the pump sucking up sediment. Five gallons seems like a bit much, though. One gallon should be more than enough.
eye95 is offline   Reply With Quote
Old 07-29-2020, 01:06 PM   #6
OldJarHead's Avatar
Fresh water capacity listed on brochures typically includes the 6-gallons in the water heater. So your FW tank may actually be a 43-gallon tank.
2015 RAM 3500 Cummins LB 4x4
2018 Rockwood Signature Ultra Lite 8328BS
OldJarHead is offline   Reply With Quote
Old 07-29-2020, 01:41 PM   #7
Is there a problem withe having a little water left?
JimMorrell is offline   Reply With Quote
Old 07-29-2020, 01:46 PM   #8
ipb
Interesting point. I hadn't thought of that; not that it really affects me practically but it would be interesting to check the volumes.
Old 07-29-2020, 01:53 PM   #9
ipb
Thanks for the idea. I think that I would be very nervous about putting a tee valve on the drain though. Because of the location of the drain underneath the trailer, it could leave the tee valve and supply line very susceptible to damage.
Old 07-29-2020, 01:58 PM   #10
ipb
I definitely agree there should be some water left but it just seemed like a lot. I drain and rinse the tank fairly regularly throughout the season and of course when I winterize it so I'm not too worried about sediment.
Old 07-29-2020, 02:15 PM   #11
BriaBeck's Avatar
Do you have any proof of this? Doesn't really make sense to me.
Brian & Becky
2018 Avenger ATI 27RBS
Champion 3500
Weber Q2000, Blackstone 22", and a whole herd of flamingoes
BriaBeck is offline   Reply With Quote
fresh water, tank, water
