Typically yes, there should be a valve (stopcock) on the outside of the tank. Just twist open to let it drain on the ground.
Alternatively, if you don't happen to have a valve for whatever reason, you could run the tap until empty. But you'd have to keep an eye on it since you don't want to run your pump dry.
